Bedford Noise Regs
Bedford Noise Regs
Just really confirming what Helen and Steve had found out. This was an email Bedford sent to one of the guys from the BMW forum. He has a CSL with an upgraded exhaust (even louder than std) and has done loads of bedford days.
However, the bit about 2nd chances seems to contradict a few peoples experience, but thats not a suprise as the office peeps won't necessarily know what goes on on track every second of a track day.
Dear XXXX
The limit at Bedford has in no way changed to what it has been over the last 7 years, nor has the way in which it is measured or inforced.
We simply responded to the forum rumours that people were given chances to run above the drive-by limit to see if they passed and were given 2nd chances should they fail. This would be illegal for the circuit (or indeed any circuit) to allow, and to our knowledge has never happened, and we have run more events at Bedford than any organiser.
All cars must pass the static noise limit tests (you are way under if tested at 96db) but also there is a constant drive-by of 87.5 at 20mtrs. Had your car broken that a few weeks back, the circut would have been under legal obligation to remove you, so you know that you were under the limit.
It is the drivers responsibility to ensure their cars are OK with limits, and it would not be possible to accuratly advise in advance if yours is.
Noise testing will be carried out in the same manner you have already experienced.
Kind Regards,
Dear XXXX
Kind Regards,
Resident Wrestling Legend
it's leagalise to stop them getting shut down basiclly
it's stating that if you fail the drive by you will be removed so you need to get it checked beforehand
you can't go there with a loud exhuast and then hope you'll be allowed on or wait for them to test you and then fit a quieter one
can't say they are being unfair
Originally Posted by martin-reyland
That email says you are way under if the static test is below 96db, I know for a fact mine is 92 but I bet I will get grief on drive by.
Do they actually eject you from the premises as I have two cars?
That was the day they lowered the drive by test due to noise LOL....
Weird that they say its never changed in 7 years.
Mine is 95db static so who cares
I am, like you, still a member of the Bedford 28
07-10-2015 12:56 PM
