Ford V6 engine whizz's help!
Old 27-01-2008 | 06:03 PM
godzilla's Avatar
godzilla
Default Ford V6 engine whizz's help!
The V6 engine thats in a Ford Galaxy, can that be found in any other Ford's and if so which ones?
Old 27-01-2008 | 06:09 PM
900ss's Avatar
900ss
RWD Racer
Its a vw engine I believe n not in any other Ford I can think of?
Galaxy and alahambra more like?
Dunnno if its a straight swap with a vr engine tho?
Old 27-01-2008 | 06:27 PM
focusv8's Avatar
focusv8
It's the same one as a VR6.
From Wikipedia.
174 hp (130 kW) VW 2.8 12 valve VR6
configuration 2792 cc Wet sumped 15° VR6
engine code AAA, AFP
head aluminum, DOHC, 2 valves per cylinder, 12 valves total,
compression ratio 10.5:1
block cast iron, 7 main bearings, bore 81 × stroke 90.3 mm (ratio 0.9), 465 cc per cylinder
fuel system Motronic ME7.1, MPFi, regular premium unleaded (91 AKI)
output 110 kW (150 hp) @ 6200 rpm, 265 Nˇm (181 ftˇlbf) @ 3400 rpm
applications VW Eurovan, VW Sharan, VW Golf VR6, VW Jetta
Awards Was placed in the 1995 annual list of Ward's 10 Best Engines.
204 hp (152 kW) VW 2.8 24 valve VR6 MOD:2004;TP{1J5863463L}
head aluminium, DOHC, 4 valves per cylinder, 24 valves total, compression ratio 10.7:1
output 110 kW (181 hp) @ 6200 rpm, 265 Nˇm (205 ftˇlbf) @ 3400 rpm
Old 27-01-2008 | 06:37 PM
godzilla's Avatar
godzilla
From Wikipedia.
Thanks for that info chap
The Corrado used a 2.9 VR6, would they share the same parts as the 2.8 VR6 do you think? I was looking at a MK2 Golf GTI today with a Corrado VR6 engine in, bloke does not want much for it so rather tempted. Thing that worries me is parts and running costs.
Old 27-01-2008 | 06:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
No idea as never looked at one, so dont know if the one in the Galaxy has different manifolds to help it fit, but for VWs...
2.9 V6 is a straight swap.
In the states they had Mk4 Golf VR6s with 24valves too.
And of course there is the R32 engine with is 3.2 24valve and based around the same design.
IIRC VW engines are all fairly well interchangable so could chuck the VW/Audi 1.8 20v turbo lump in there too.
And yeah, parts are common as muck.
Old 27-01-2008 | 07:08 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Steve do you know if the VR6 fits in a T4 transporter
Old 28-01-2008 | 11:39 PM
James's Avatar
James
probably, they did the same engine in the t5 transporter [r32 lump, rebored 2.8 essentially]
the 2.8 24v also came in uk golfs, badged as 2.8 4motion.
Old 28-01-2008 | 11:42 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Mmmm tow van project coming up
Old 28-01-2008 | 11:43 PM
James's Avatar
James
probably get better mpg with a cossie transit tbh!
for ultimate insanity they did a 2.8 vr6 automatic 4x4 galaxy
Old 28-01-2008 | 11:45 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yeah but a cossie transit will break down as well
Old 28-01-2008 | 11:48 PM
James's Avatar
James
http://www.pistonheads.co.uk/sales/347946.htm
Bailes1992
16-08-2015 08:14 PM
