Melted plug ?
Old Jan 25, 2008 | 07:39 PM
mitchrst's Avatar
mitchrst
Default Melted plug ?
Fook ive melted a plug tip in my rs turbo what damage could it of done if any ?
Old Jan 25, 2008 | 07:46 PM
JonnyBravo's Avatar
JonnyBravo
Coudl well of done a piston too mate, I done a plug in my xe nova, it still ran ok with a new set so I left it, when I took the head off there was one lo comp piston
Amazing how well it still went and i still ran a 13.05 1/4 with it like it
What plugs are you using ? you may of just done a plug
fingers crossed for you
Old Jan 25, 2008 | 07:53 PM
RickyLee53's Avatar
RickyLee53
Compression test it before u put a new set in i'd say.
Old Jan 25, 2008 | 07:55 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
ooooooh
Old Jan 25, 2008 | 07:57 PM
mitchrst's Avatar
mitchrst
pp8 cossie plugs running 16psi
Old Jan 25, 2008 | 08:03 PM
JTECH James
Passion for Fords!
they are a very hot plug those pp8s, i lost a yb due to them.....
Old Jan 25, 2008 | 08:37 PM
JonnyBravo's Avatar
JonnyBravo
bcr8es iirc is what I run.
Standard RS Turbo plug iirc
A mate has used them without any problems @ 400hp on a LET
Old Jan 25, 2008 | 08:54 PM
JTECH James
Passion for Fords!
071c is fine to
Old Jan 25, 2008 | 09:11 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
did 3ish on my saff years ago at a speed indicated 150mph having a do with a camero, drove 25 mile home and changed, all was good lol lucky as!!
Old Jan 25, 2008 | 09:50 PM
mitchrst's Avatar
mitchrst
Just shows how shite these cosworth pp8s plugs are dont it if they cant even handle a rs turbo running 16 psi
Old Jan 25, 2008 | 09:57 PM
MK5RST's Avatar
MK5RST
There has gott be a problem somewhere for it to melt a plug, faulty injector maybe?
Old Jan 25, 2008 | 11:38 PM
RAT8OY's Avatar
RAT8OY
Sounds like you have got detonation issues mate.
Det explosion is massive, no plug or piston in the world will stand up to heavy detonation.
You may well get away with just new plugs, but get it looked at before you drive it/hard again.
May I suggest the fuel pump wiring?
Old Jan 26, 2008 | 12:03 AM
Fiecos Dan's Avatar
Fiecos Dan
Those plugs do melt, but fueling is usually slightly lean (or det is present)
your need to do a leak down tst and comp test to check for damage.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
