Throttle postion sensor help?
Old Jan 12, 2008 | 11:45 AM
daviddunlop83's Avatar
daviddunlop83
Default Throttle postion sensor help?
Hi, can anyone tell me how to set the throttle position sensor please?
Thanks
Old Jan 12, 2008 | 04:11 PM
blacky.'s Avatar
blacky.
i no this might sound daft but on what car
without ant info on the motor people wont be able to help you
Old Jan 12, 2008 | 04:14 PM
GARETH T's Avatar
GARETH T
PF01 ONLY
Disconnect the ecu multiplug from the ecu itself and then with a multimeter:
Pin 1 of ecu connect your negative probe.
Pin 17 of ecu connect your positive probe.
Adjust the sensor until it is just open circuit and ensure it drops to a reading the moment the throttle is moved, but be certain it always goes open circuit with the throttle released.
PF09 ONLY
Plug the ecu multiplug back into the ecu and turn on the ignition.
Adjust the sensor to read <0.35volts at idle position.
Old Jan 12, 2008 | 04:16 PM
GARETH T's Avatar
GARETH T
you have either not checked on the other thread your started on stus forum! or just ignoring my answers! just like you did the other day!
i get the hint,,, i wont reply no more
Old Jan 12, 2008 | 04:23 PM
Fiecos Dan's Avatar
Fiecos Dan
i'll give you one of these Gareth
Save'd me writing it.
ps, 01 = 2wd, 09 = 4wd TPS.
unless he's talking about a RST?
Old Jan 12, 2008 | 04:38 PM
GARETH T's Avatar
GARETH T
http://www.fordrsforums.co.uk/viewtopic.php?f=1&t=855
he got a three door
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
