YET ANOTHER BIG POWER ENGINE ON SECS S8 ECU - 632 BHP
Old 13-10-2004, 06:46 PM
ECU Monitor Enthusiast
Default YET ANOTHER BIG POWER ENGINE ON SECS S8 ECU - 632 BHP
Sorry everyone this is a blatent advert for me and a few others....
This afternoon, my friend Nick Lewis (a NEW PF user NIL 7090)
had his cosworth YB engine dynoed at Norris Designs.
The engine specification is as follows....
ENGINE SPECED/BUILT BY NORRIS DESIGNS (DAVE MIDGLEY / SIMON NORRIS / NICK LEWIS)
MAPPED BY SIMON NORRIS
HEAD PORTING AND TEA MAKING BY SPENCER ATHAY (aka PF spenner)
CAPACITY 2.0 LITRES
JE PISTONS TO NORRIS DESIGNS SPEC.
COMPRESSION RATIO (NOT DISCLOSED)
4 x 1000cc SARD FUEL INJECTORS
SWEDISH INLET MANIFOLD (SUPPLIED BY MIKE RAINBIRD)
METRO 6R4 THROTTLE BODY
GARRET GT30/40 HYBRID WITH EXTERNAL WASTEGATE
BOOST LIMITED TO 2.0 BAR AT ALL TIMES ELECTRONICALLY
8200 rpm REV LIMIT
PORTED HEAD (STANDARD SIZE VALVES)
CAMS NORRIS DESIGNS SPEC.
CAM VERNIERS
SOLID LIFTERS
LONG STUDDED HEAD BOLTS
METAL 3 LAYER HEAD GASKET
LIGHTENED FLYWHEEL
BLUE PRINTED AND BALANCED CRANK/RODS
HIGH FLOW PISTON OIL JETS
OIL COOLER
SPEC R CUSTOMISED 4 PORT BREATHER SYSTEM
ALLOY CRANK PULLEY WITH IRON LUGS FOR CRANK SENSOR
SECS S8 ENGINE MANAGMENT
SECS S8 COIL PACK IGNITION SYSTEM
5 BAR MAP SENSOR
CLOSED LOOP LAMBDA FUELLING (NOT AT FULL LOAD)
The engine was initialy started and mapped for idle and acheives a stable idle
at 1000 rpm with a lambda reading of 1.00 (AFR 14.7:1)
Then the engine was fully mapped with a flat line controlled maximum boost of 2.0 Bar.
The fuel was then changed for race fuel and the ignition table modified and then
a second maping session with power run was made.
I wanted them to run a bit more boost personally but the engine was mapped conservativley
due to Nick shitting him self and not wanting to rebuild it too often !
I must say I have rarely seen such a flat torque curve as on this engine and remember
it is torque that gives acceleration.
Just remember, this is ONLY still a 2.0 litre and does NOT run NOS.
I cannot give any further specifications/details as these were not given to me and/or
the engine builders were keeping it a bit quiet.
The results....
PUMP FUEL 97 RON: 584 bhp @ 7440 rpm / 450 lb/ft @ 6090 rpm
RACE FUEL 118 RON: 632 bhp @ 7650 rpm / 474 lb/ft @ 6040 rpm
I have posted a few piccys....
PUMP FUEL: POWER RUN GRAPH
PUMP FUEL: POWER DATA TABLE (LAMBDA READINGS ARE NOT CORRECT HERE)
PUMP FUEL: PRESSURES DATA TABLE
RACE FUEL: POWER RUN GRAPH
RACE FUEL: POWER DATA TABLE (LAMBDA READINGS ARE NOT CORRECT HERE)
PICTURES OF THE ENGINE ON THE DYNO CHASSIS
NICK PRETENDING TO BE A MAPPER
Bugger, forgot to get pictures of ECU
Thanks to Nick Lewis and Simon Norris for putting faith in the S8
Right, let the put downs comence .....
Old 13-10-2004, 06:49 PM
Phil
Jeebus
Phil's Avatar
Excellent work!!! Just look at that torque line!
Old 13-10-2004, 06:51 PM
TIFF
Chasing Radders
TIFF's Avatar
TOP WORK SIMON AND ALL INVOLVED
Old 13-10-2004, 06:52 PM
Nick500
Nick500's Avatar
Respect!
Disabled Account
Disabled Account's Avatar
Simon, would have been good to see a run at 2.2/2.4 BAR
Me next!!!!!!
Paul Eggleton
Paul Eggleton's Avatar
Fair fucking play. Nice one.
I didn't realise just porting the head would allow it to flow enough to reach that power.
Old 13-10-2004, 06:53 PM
Karl
Norris Motorsport
Karl's Avatar
Superb Simon. As you say would have been great to run a touch more boost.
I think the torque curve is fantastic!
Old 13-10-2004, 06:54 PM
Rob M666SCC
Rob M666SCC's Avatar
Well done boys
Old 13-10-2004, 06:55 PM
Phil
Jeebus
Phil's Avatar
Std size cossie valves are good for over 600bhp I had been informed previously
Jamz
Jamz's Avatar
Grats mate, really pleased for you It must be really satisfying seeing your own product perform so well.
There is MORE to it than that. Cams/Manifold/turbo ... MONEY
Old 13-10-2004, 06:57 PM
Thanks for that Karl. It means alot when someone of your reputation
makes such a statement.
Unfortunately, I can only take credit for the ECU system.
Old 13-10-2004, 07:00 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Fair play, esp the good power on pump fuel
Old 13-10-2004, 07:04 PM
Paul Eggleton
I know it needs a good combination of the above, I just imagined that at that level bigger valves would have been a given seeing as people tend to say that you need headwork for a genuine 400.
GARETH T
GARETH T's Avatar
impressive torque curve,,, will make a crackign fast car! the torque hasnt tailed much
Old 13-10-2004, 07:05 PM
SteveB
SteveB's Avatar
Disabled Account
Some stats:
Add together the BHP output of Porkie's, Brom's and Nick's engines - ALL running SECS S8....and you got 1,856 BHP
Then add Phils DIY engine (488 BHP) ??????? whats the total for the four engines?
2,344 BHP ???
Old 13-10-2004, 07:06 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
is very impressive any idea on the crank just for interests sake?
Old 13-10-2004, 07:07 PM
timrud
timrud's Avatar
What car is it going in? 2wd or 4wd?
Immense torque curve!
Karl
Norris Motorsport
Karl's Avatar
Doug, then fit them all in one car. LOL
Old 13-10-2004, 07:08 PM
I THINK the crank is standard apart from being knife edged and surface
tension relieved by shot peening.
Disabled Account
Hhhmmmmmmm I wonder
Old 13-10-2004, 07:09 PM
spenner
spenner's Avatar
WHAT A TOP RESULT ALSO VERY QUIET ENGINE AT HIGH REVS SOUNDED LOVELY WELL DONE NICK MINES NEXT OH BUGGER WELL DONE NORRIE WHAT A PUKKA JOB AND DAVE TOP ENGINE BUILDER AND SIMONS E.C.U IS THE DANGLIES BOUNDARIES ARE NOW BEING PUSHED 700 THE NEXT MILESTONE WITHOUT NOS ANY TAKERS
Old 13-10-2004, 07:10 PM
Its going in a 4wd saffy with all the trick transmission.
Dont know what type this will be though.
Old 13-10-2004, 07:11 PM
spenner
spenner's Avatar
THE CARS A 4WD SAPPH
Old 13-10-2004, 07:13 PM
Mark Shead
Mark Shead's Avatar
Simon I bet Nicks happy Cant wait till he starts going to the shootouts will be very fast,
You may want to edit and put in Who did the head work as you never know who will take the credit .
Mark
Old 13-10-2004, 07:15 PM
Karl
Norris Motorsport
Karl's Avatar
Is that another unecessary Dig Shady?
Disabled Account
Simon, can you say who did the head work???
Old 13-10-2004, 07:16 PM
timrud
timrud's Avatar
Can't wait to see the car in action then!
Wonder what 0-100 times it will set? Should be knocking on the door of Martooon with the race fuel in?
Mark
Sorry, forgot. Thanks for the reminder.
It was that chap "spenner" who did the head job
Old 13-10-2004, 07:18 PM
Disabled Account
Spenner did the head work AND made the tea?????????
Old 13-10-2004, 07:19 PM
RWD_cossie_wil
DONT TURN THIS INTO TUNER WARS FFS
Old 13-10-2004, 07:20 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
FAIR PLAY MATE
very good result!!
TOP ROD!
Old 13-10-2004, 07:21 PM
AGREE 100% - Just because 1 person/tuner has big power does not mean
no one else cant do the same !
Old 13-10-2004, 07:25 PM
avengerpenguin
avengerpenguin's Avatar
Well done Simon, and all others concerned
Old 13-10-2004, 07:27 PM
Mark Shead
Mark Shead's Avatar
Yes I forgot Spenncer did the head He always makes the tea , Cant wait till he goes for 1/4mile and top speed It should be on for 195+mph .
Mark
RANJ
RANJ's Avatar
wel done simon and nick etc etc
good to have it finally sorted hey
Old 13-10-2004, 07:30 PM
madevelopments, Thanks for the positive comments Mark.
I am sure Nick will have a play with the big boys one day soon.
Old 13-10-2004, 07:32 PM
CozzyBrom
CozzyBrom's Avatar
not a dig or anything but why wasnt trick rods used so the revs can rise to high 8000 looking at that surly would see well over 600 bhp on pump fuel if the revs where to climb and more boost
well done carnt wait to get mine strapped on the dyno so see what it will put out wont be long now
Old 13-10-2004, 07:33 PM
RANJ
RANJ's Avatar
nice dyno proven what we like to see aswell
Quick Reply: YET ANOTHER BIG POWER ENGINE ON SECS S8 ECU - 632 BHP
