YET ANOTHER BIG POWER ENGINE ON SECS S8 ECU - 632 BHP
Old 13-10-2004, 08:38 PM
  #81
NIL 7090
NIL 7090's Avatar
Thanks simon, thats what i was going to say!
Old 13-10-2004, 08:40 PM
  #82
GT2
GT2's Avatar
What kind of output energy(spark) will it give?
And what kind of valve will be used when the S8 is going to control the boost?
Old 13-10-2004, 08:41 PM
  #83
spenner
spenner's Avatar
HELLO NICK HAVE YOU LANDED YET OR STILL ON CLOUD 9
Old 13-10-2004, 08:44 PM
  #84
GT2
GT2's Avatar
Is it possible to run 4 singel coils aswell?
And the 5 bar map..is it the same one that Phil (Big Bosch man) sells?
Old 13-10-2004, 08:47 PM
  #85
ECU Monitor Enthusiast
Originally Posted by GT2
What kind of output energy will it give?
Never measured it directly at the HT end but current consumed
by the coil is substantial when on boost/rpm.
Sorry. Dont have any specific measurements.
All I can say for sure, so far is NO special CDI ignition unit has be
required or used with S8
We were running 0.65mm plug gaps without a hint of missfire on boost.
This also helps us get a decent idle quality.
Old 13-10-2004, 08:49 PM
  #86
Yes it is possible to run 4 coils in a future software upgrade available
within the next month or so.
Yes the 5 bar map as sold by Phil is fully compatiable and requires
no calibration to work.
E.G. A car mapped on 3 bar sensor, only 1 setting is changed to use
a 5 bar and NO remapping will be required except to cater for more boost
if the additional range of the 5 bar is used.
  #87
Originally Posted by NIL 7090
Hi rod, whats happening in January?
PF Thrash at Brunters Nick, just the event to see what she will do.
Great feeling aint it, told you it would work out OK.
Rod
Old 13-10-2004, 08:54 PM
  #88
GT2
GT2's Avatar
Thank for answers Simon...
Old 13-10-2004, 08:59 PM
  #89
The S8 can use either Air injectors (YAWN) as per other cossies,
the standard amal valves (Escort cossie best one).
Or you can attach an aftermarket high speed valve such as the
one used by Greddy/Blitz etc.
The control output can either be programmed to be on/off for specific
engine conditions or can be used as either high speed or low speed
pulse width modulation (PWM) for mapable boost with RPM/LOAD.
Now Im out of breath......
Old 13-10-2004, 09:08 PM
  #90
Hardeep_Singh
Hardeep_Singh's Avatar
weldone to all involved
finally some putting in a big power cossie engine in a 4x4 sapp the times should be interesting can't wait
Old 13-10-2004, 09:13 PM
  #91
GT2
GT2's Avatar
So it uses just the valve and not the electronics box...
thanx Simon..
Old 13-10-2004, 09:17 PM
  #92
GT2, Spot on !
Old 13-10-2004, 09:27 PM
  #93
marco polo
marco polo's Avatar
to everyone involved
Old 13-10-2004, 09:46 PM
  #94
ADUSR33
ADUSR33's Avatar
excellent result to all involved... ...s8 seems to be the dogs danglies
Old 13-10-2004, 09:50 PM
  #95
mybluechicken
mybluechicken's Avatar
Impresive figures!!!
Old 13-10-2004, 09:52 PM
  #96
RichardPON
RichardPON's Avatar
Really coming together now Simon!
Congrats to all involved - these ECUs are looking more tempting by the minute!
Old 13-10-2004, 10:11 PM
  #97
Stavros
DEYTUKURJERBS
Stavros's Avatar
Originally Posted by Porkie
Originally Posted by GARETH T
i didnt think simon had done a 0-100 in 5.5,,, thats just unreal
OFF THE FOOKING CHARTS
AND he did it with 200mph gearing! sooo impressive.
Whats even more impressive is that was from a FAR from perfect launch! The way the timing gear works is it triggers once theres ANY movement, and Simon found it impossible to totaly hold the car in place with the launch control etc going on, so the timing gear started probably a good 1/2 second befoire he actually launched it!
Now its got a proper gearbox that car is fookin craaaazy
Old 13-10-2004, 10:21 PM
  #98
Steven_RW
Steven_RW's Avatar
Sounds like a decent motor to me. Nice work chaps
RW
Old 13-10-2004, 10:30 PM
  #99
PGT
PGT's Avatar
top work guys - should make a superb road engine with that tork curve -how much for a turn key copy?
Old 13-10-2004, 10:33 PM
  #100
Over Ł10000 I think - But dont quote me on it !
Old 13-10-2004, 10:36 PM
  #101
ADUSR33
ADUSR33's Avatar
10 gees seems quite cheap to me for that power....with that torque i bet it pulls like a train
Old 13-10-2004, 10:39 PM
  #102
Thats about what it cost at mates rates - The "real" price has not even been thought about for fear of heart attack !
Old 13-10-2004, 10:41 PM
  #103
ADUSR33
ADUSR33's Avatar
yeah mates prices are always better
Old 13-10-2004, 10:48 PM
  #104
The attention to detail in this engine build is mind blowing.
Here are a few things that were done......
ALL edges on the inside and out have been deburred/chamfered down to save weight.
(and prevent engine builder from cutting himself)
All internal bolts/nuts are stainless steel wired to prevent them coming loose.
EVERY bolt/nut during construction was torqued and logged on to a record sheet.
Old 13-10-2004, 10:53 PM
  #105
RSCossieGaz
RSCossieGaz's Avatar
serious piece of kit there
Old 13-10-2004, 10:55 PM
  #106
ADUSR33
ADUSR33's Avatar
to be honest i didnt even know norris designs did cossys
Old 13-10-2004, 11:20 PM
  #107
richm
richm's Avatar
sounds like neither of us are not very mechanically minded! Fingers and thumbs and a bit of blood comes to mind!!
stick to cooking eh Nick..
nice result there!! you'll be getting you're moneysworth out of yr roadtax soon then, melting all the tarmac round here..
Rich
Old 13-10-2004, 11:28 PM
  #108
sunny
sunny's Avatar
Well chuffed for ya Nick!
Also nice seeing people doing things properly using engine dyno's.
Bests - Sunny.
Old 13-10-2004, 11:36 PM
  #109
RWD_cossie_wil
RWD_cossie_wil's Avatar
If you want a hand putting it all back in the car I am in swindon all week every week
Old 14-10-2004, 12:35 AM
  #111
Fastmaul
K155MYRS
Fastmaul's Avatar
Nice work!!!
now put it all together and see how much of that bad boy power gets transfered to
the wheels!!
Old 14-10-2004, 12:55 AM
  #112
Stavros
DEYTUKURJERBS
Stavros's Avatar
the wheels!!
Best thing said so far
Old 14-10-2004, 07:50 AM
  #113
Rene
Rene's Avatar
Top result !!!! for all involved!
i want in to!!!!
please have my babies!!!!
Old 14-10-2004, 07:56 AM
  #114
NIL 7090
NIL 7090's Avatar
thanks again for all you'er offers to help but i am going to take my time putt'ing it a
ll back together,and hopefully it will be ready just after christmas.
richm,thanks but i think you could be spot on!!!!!!
sunny,thanks very much,you know its the only way to map an engine
Old 14-10-2004, 08:00 AM
  #115
Spiky
Spiky's Avatar
top result
bet you running around like a dog with two dicks
Old 14-10-2004, 08:06 AM
  #116
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Originally Posted by cozzybrom
well simon you know the plans when i get me box here am takin engine out and i want to take it to simons and strap it on to see what its putting out at 2.6 bar and 8800 rpm
am hoping to be in the 600 club proven then
According to you, I thought that engine dyno's were supposed to be for just "pub talk" - glad to see you have finally woken up and smelt the coffee .
Congratulations to all involved .
Old 14-10-2004, 08:10 AM
  #117
space hoppers
space hoppers's Avatar
spence your tea is like warm milk so the mrs said. glad to see people prasing all concearned about time as there is too much bitching on here tell nick too get it in the old rusty nail
Old 14-10-2004, 08:20 AM
  #118
space hoppers
nick your balls still aint as big as mine even with all that power ha ha
Old 14-10-2004, 08:23 AM
  #119
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Excellent looking power curve, very impressive
Thats going to do some serious damage out on teh road, take it easy out there
Old 14-10-2004, 08:29 AM
  #120
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Lovely power curve. well done all involved. Cant wait to see it go.
Quick Reply: YET ANOTHER BIG POWER ENGINE ON SECS S8 ECU - 632 BHP
