FAO Mondeo peeps (Water leak)
Right the carpet on the passenger foot well is damp. Thought i had it sussed the other day, but i dont as its getting damp again. Any idea or common places for water to seep in through and go onto the passenger footwell?
what model is it 1,2, 3 or even 4 ?
anywayI'm pretty sure it will be the pollen filter seal, this is under the black plastic cover between the bonnet and windscreen on the passengers side, remove the cover and then the cover on the filter, remove filter, clean the area fit new filter and ensure it's clipped in correctly and refit covers job jobbed..
steve
steve
Pull back the carpet as there are plastic grommits in the footwell that i hav eseen disapear , this happened on my bro's mrk 1 mondie a few years ago !!
Also check door seals etc and you heater matrix is the worst case
Also check door seals etc and you heater matrix is the worst case![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
steve
(ford mondeo breaker
Its a Mk2 two
Sounds like coule be pollen filter as i know this has been changed recently before i had it. Will check tomorrow.
Would this only going over to the drivers side though Steve?
Sorry mate trying to two things at once
AS you can see i cant multi task
If the pollen filter is fitted incorrectly, would this only cause a leak to happen on the drivers side? Or could it also leak on passenger side?
Or is it just the way the luck falls and the way its sealed, ie wrong on drivers side part, hence leak over there.
Will have play tomorrow, will also pull edge of carpet up make sure everything is ok underneath
the pollen filter is on the passenger side hence why it only leaks on that side, if both front footwells are wet then you may have a pond in your pollen filter or another leak on the drivers side, what tho I'm not sure as I have never seen one,so not had to look there
steve
steve
Just changed the pollen filter on my estate mondie yesterday and what a mess ...................do some folk never ever think of checking these aswell as changing air filters etc etc
Could tell with the state of mine that it had never been done in the 65k life its had since 1999
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
Could tell with the state of mine that it had never been done in the 65k life its had since 1999![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
the fans whizz round now!!
steve
Fuck i am one of the biggest pricks going!!!!!!!!!!!!!!
Started this thread saying passenger side
When i meant to say drivers side only. Hence why getting confusion with pollen filter
Now i dryed the carpets out when i got the car and all seemed well until todays rain. Where im resting my feet for accelerator etc its started to become damp agian. Its dry by the door, centre console ,front and back but where I put my feet it damp getting wet. Thinking its where my feet or pushing it doing is soaking it up. YOu think this might be still pollen filter related? As said will pull carpet up as much as i can without taking seat out, to check floor.
Posy thing i hate little things like this.
feet found, i have 2
On my mk1 the rear screen washer pipe had split, somehow i dont know, but when i tried to squirt the rear window it cleaned my head!
And on the mk2 its broken somewhere under the front arch so dosnt even reach anywhere near the cabin...
In saying that, I'm sure the last owner had a roof rack on it and isn't there some sort of rubber seal where that screws or bolts into in line with the top of the drivers door?
Right peeps found the problemo, quite a simple one
The rubber gromets on the floor are missing. So for now some Gaffer tape until get the gromets from for this week
![Name: MondeoFloor.jpg
Size: 64.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/154834d1502131792-fao-mondeo-peeps-water-leak-mondeofloor.jpg)
Least its nice easy fix
Yeah Nath when got car home pulled up mat to hovver and floor was soaking wet
Least found out easy fix now.
Right after fitting the two gromets, it now looks like carpet is getting damp/wet again
So im either thing seal across bulk head (will whip cowling of by wipers etc tomorrow. Or worst case im worrying is matrix!
Anyone know any ideas to easily identify? not an impressed person
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
Mark RS
12-10-2015 06:01 AM
