1st 6 months of cosworth ownership !!
#47
Originally Posted by Escy
so your impressed that your car lasted 3000 miles without incident?
what a joker
what a joker
most of me mates who got cosy spend more time being fixed than they get to drive them
Just look above at what as gone wrong with a few peeps cosy bet they had not done much more than 3000 miles if that
All i am saying is that most peeps reckon there unrelable you get probs all the time
#49
if you do 10k with no problems then it would be IMO. (i bet even new cossies had trouble with this!)
#50
Got mine 2.5 years ago
After 40 miles of ownership the tensioner stripped out of the head, bending all the valves and damaging all the pistons - complete rebuild approx £1700
New MAP sensor, dizzy cap & rotor arm to fix intermitant misfire
One of my cams came loose while gunning it, luckly i stopped in time. Turns out the studs stripped out a bit in there too.
Radiator fuse kept melting, had to re wire the whole lot.
Now i've got 2 snapped exhaust manifold studs flush with the head which is why it's dead at the moment.
I use it for work (when it's going) and have done 15k in the 2.5 years, the car itself is showing 131k on the clock.
I'd say you have been lucky but you don't do enough miles to worry too much mate
Cheers,
Dave
Cheers,
Dave
#57
Originally Posted by Rs Gus
no i couldnt do it to it tony
I need to copy someones ideals whants doing next
rog
04-09-2015 12:10 PM
bigluke200
14
02-09-2015 10:35 PM
