Brakes...WHICH ONES!!!
PassionFORD Member
Hi all,
I have a 2003 1.8 MP3 focus with brake disks front and rear. All are in need of changing soon and I am sooo confused as to what to get.
I;ve had a look at black diamond disks and predator pads all round and also EBC turbo grooved disks and mintex xtreme and greenstuff pads.
I am also aware of certain Tarox products as well but there are so many out there and so many companies offer different disks and pads at all roughly the same price so I don't know what to get.
Could anyone please advise?
Much appreciated
Much appreciated
You are not going to see a huge benefit of going up from 278mm to 300mm, and then have to get brackets etc made.
Moneywise better off with decent pads discs.
The choice of disc is up to you, I would get either grooved or EBC dimpled and grooved, I would then use these with EBC YELLOWSTUFF TRACK PADS.
They WILL work perfectly from cold, they do not squeal, even when removing the anti rattle shim on the the rear of the pads, as I have.
I use Yellowstuff myself, having used ferrodo DS 2000/25000/3000 Mintex 1144/1155/extreme/pagid etc over the years I now use the above pads EBC YELLOWSTUFF, they are one of a very few approved for police pursuit use as well, this is because they will act like an old granny pad tootling aron dtown and a boy racer pad when needed.
If you haven't already get braided hoses too, and change the fluid.
PassionFORD Member
I've had a second recommendation on rally design as well.
Interesting points raised by tabetha and my brake lines are braided already. Seems EBC disks keep getting the thumbs up so may go turbo grooved as I was thinking of (drilled and grooved). Will look at yellow stuff pads as well but haven't come across them yet.
EBC direct.com
Ebc discs used to be crap, I know have used enough, some went back the same day under warranty.
Greenstuff is now V7 version, and are utter crap, the older V4 was actually quite good, but anyone that says they(V7) are good does not use brakes.
I have them on a astra 1.4 auto, drilled discs and fade them nearly every week, car is std as well, would not put them on a bicycle myself.
PassionFORD Member
right sorry to bring this up again but from speaking wiht a friend, the rears don't actually contribute much to the braking as much as the fronts?
Is this the case?
Because if it is I'd rather just replace the pads at the back with the same ones again (mintex xtreme) as the disks are fine and spend more of my budget at the front and get a nice set of Tarox G88s I found the other day.
Is this the case?
Resident Wrestling Legend
yes, the front does about 70-90% of the braking over all
the rears are there to stop the car getting upset when you brake into corners and such
bolt in a new set of pads int eh rear and then think about saving a stack of cash and go for soemthing like a 330 kit
you'll never realisticaly need to change these ever again other than a set of pads
Twistin me melon man
if you use the drilled/grooved disks from ebay seller mtec100 they are excellent quality and amazing price, i use them with EBC greenstuff pads.
greenstuffs dont give off much brake dust, which is nice...
black diamond are good but cost nearly 3 times as much.
EBC turbogroove start juddering and cracking up within a few months of purchase
PassionFORD Member
thanks people.
I think what I'mprobably going to do is just give the rear discs a clean and stick fresh pads on and get Tarox G88s on the front
A mate has them on his Evo and had them on his FRST as well and never had problems. And the Evo has twice the power I have
Can't really afford a 330 kit right now unfortunately and don't really have enough power to justify doing it but later on might need to think about doing it
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
14000+ post superhero
Originally Posted by tabetha
EBC direct.com
I have been looking at these as well and they look very cheap. Do you know where they're made? Are they Chinese? Have you had any trouble with them?
Charlie
Charlie
PassionFORD Member
I've just ordered mintex vented discs at the front with mintex xtreme brake pads and a brake box kit at the back consisting of discs and pads..
Cost me £110 in total for all 4 discs and pads.
Charlie
Charlie
