VIDEO OF MY NEW ENGINE RUNNING ON PAGE 2 :D
#121
Originally Posted by Chip-3Door
Yes mate, that was a typo on the crank, its an XER, and yes I used an ecotec pulley for it.
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Look forward to seeing it being used in anger
#122
Garage19, I'm running a .82 exh housing.
Chip, I wondered if you would silence the screamer seperate, or flow into the exhaust.
Just thought afterwards, my civic turbo runs an external 38mm (overkill) but the gate positioning is very poor, this still holds boost perfectly, but obviously its a smaller engine (1.6) and much lower powered.
I'm running Arais pistons as well, what piston to bore clearance did you go for, and what piston speeds do you think you will see when its built?
#123
86mm stroke, I wont be able to rev it past 8500rpm unless I drysump it which im not intending at the moment.
Ive gone for a 4.5 thou piston to bore clearance, on an 86.75mm bore.
Thats a little higher than is typical, but I want it not to seize up if I squirt a little bit of gas into it now and then
#125
Exhaust has now moved, and ive cut a hole in the boot for it to come out, so the boot shuts now, although it needs some serious tidying up as its just a dirty great angle ground square hole its coming out currently!
I'll sort it, just got more important things to do first, like putting pinch bolts in the bottom ball joints for example
#129
Thats a little higher than is typical, but I want it not to seize up if I squirt a little bit of gas into it now and then![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
#130
Not bothered at all by how it sounds when cold though obviously on this sort of car, its just all about stopping it blow up!
#131
#133
MAD Carbon Cossie
Chip,
Will your GT35 not surge on a .63 ? ? ? Has the head been majorly flowed for it then ? ? ?
Jus curious !
Keep the piccy's coming, lovin this Nova (never thought I'd say that !
jb
Jus curious !
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
jb
#134
Head is a pretty large spec, although the valves themselves are only 1mm oversized, which is still 1mm smaller than cossie ones.
Its got a very good port job on it though, and im not expecting it to surge like on a YB as its a better shape to begin with anyway IMHO
Im also NOT after massive midrange torque anyway (due to traction) and thats when you tend to get surge, when you have huge boost at medium rpm.
Head was done by Neil Roper developments (Neil is Ex Hart formula 1 and a bit of a legend with RS200 heads as he did the works cars, so good background to come from)
#135
MAD Carbon Cossie
Argh ok cool, so if it does surge your'll jus cap it till the engine speed builds enough to cope ?
Traction is a problem for me too
but thats what I seem to like the most, the car lighting up the tyres in the 1st 3 gears wet or dry & no clutch tricks
So midrange torque is important to me !
So are you gonna run 2 silenced exhausts, one for screamer & the other for engine or link em both together ? ? ?
jb
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
jb
#136
jb
jb
for track days im going to run an extra silencer on the outside of the car across the boot.
#137
jb
jb
#138
Hey chip,
Ass well as weling up your CC on sat i've just been asked told the secret squirell top spec LET inlet will be ready for the first non cast protype to be welded up.
#139
Is this the mad spec engine that was due to go in your old mini some time ago?
Also can I ask what is your cooling set up for the engine? Rad mounted at front i am assuming? Trying to sort mine out next few days. Is yours just standard i.e. Longer pipes and thats it? Just wondering if there will be any issues going from front to back in terms of the water pump, or extra capacity or air locks? cheers
#141
And yes, its the engine I was going to put in my mini, but Ive decided to stick to about 250bhp for that.
#142
are you sure 250bhp is gonna be enough in a mini chip
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#154
Here is a picture showing the exhaust mocked up in its final location before doug finally TIGed it exactly where I wanted
sadly its a picture in the dark but still pretty easy to see.
![](https://i7.photobucket.com/albums/y251/chip-3door/4m2/new-engine/exhaust-final-mockup.jpg)
And here is, well, im not sure how to describe it TBH, LOL
![](https://i7.photobucket.com/albums/y251/chip-3door/4m2/new-engine/exhaust-pratting-about.jpg)
#155
"Alas poor Yorick, I knew him well"
![](https://img.photobucket.com/albums/0803/stirling/chip2.jpg)
#157
you being a retard
must admit, that exhuast does look a bit better than our effort from before
