Im no engineer, but this has to be dangerous!!!
surely this is an accident waiting to happen!!
http://cgi.ebay.co.uk/GROOVED-LIGHTE...QQcmdZViewItem
steve
steve
as long as there has been suitable stress analysis in the structure and has been tested for fatigue then it will be safe, loads of fly wheels have portions removed (although not as extreme as the disk in that auction).
Interestingly overall stress can actually be reduced by removing parts of a structure, providing they are the correct parts, and by curving corners of voids the stress concentration can also be reduced.
I doubt very much tho that the appropriate testing has gone into those disks as the lightening looks far too extreme for my liking.
for some reason the actual ring part off the disc looks too thin, maybe a 6mm wall thickness on them (thinnest part any way) the holes are just asken for the disc to explode/part company with the bore part tho.
as some people say the only thing between you and the road is your tyres.
well for this instance the only thing stopping you and the wall/car/hedge/kid on bike/bus etc colliding(sp) is your brakes.
Hmmmm..... If you look at where the stresses will be on the discs, there is still a fair bit of meat around the studs, but I doubt very much wether they have been professionally tested for stress/fatigue etc. Reducing unsprung weight is a huge step to making a car handle better, every 1kg of unsprung weight is equivilant to saving 20kgs of sprung weight according to most tech articles I have read. Still wouldn't fancy running them on my car though, don't think the insurance companys would be too happy either
There is absolutely no corrrelation between unsprung weight being or having an equivalent.
It depends on so many factors like, weight of component weight of car, and most importantly SPEED the component is rotating at, in the case here.
I would not do it on a road car, which weighs a lot more, than the kits they are intended for, and therefore generate a lot more heat.
Resident Wrestling Legend
the hoels they've made in the sides are fairly common on production cars, audi's for example have them
the holes i the top thought wold concern me a little more as it seems ther is just a bit oo much meat missing from the disc to make it stable through it's heating range without it warping
tabetha is correct when he mentions that it's for a kit car so won't have to lsow down as much, but if it does all go wrong it's still a kit car which someones spannered together in ther garage and it won't have as much protection if it's gone into a brick wall faster than the driver wasn't expecting it to go into
