excessive oil consumption on e39 bmw
Was speaking to a mate yesterday with a e39 520i, now it is using lots of oil, blue smoke out the exhaust, the works, he was coming home the other night and it went down on to 5 cylinders, went to change plugs and plug number 3 was oily, done a compression test and number 3 was down to 110 psi where as the rest are up at 180psi. he was wondering what could be wrong with it! rings? etc
Now i think its not to bad, i think that the head gasket is away between the oil way and cylinder 3 causing the oil to go into the bore, oil up the plug and its blowing oil out the exhaust causing the smoke! does this sound possible?
