show us your secure battery trays/boxes
i have a red fibreglass battery box like burtons etc all sell,
it is bolted to the car via 4 bolts and big washers to stop them ever pulling through,
BUT.........it worrys me that in an accident the box could shatter/split and the battery fly out as only the lid holds it in
you think these are safe?
i used to have a proper ford battery tray welded in the boot but binned the when i put the fuel cell there,
heres my current item
Marc, i use a plastic battery box which is bolted down like yours, but the battery is also clamped down, i used two pieces of 6mm studding slighty higher than the battery, then a piece of alloy angle with two holes drilled in either end bolted across the top, that fooker aint going anywhere.
Originally Posted by leecavturbo
i think this post is just to show off your
awesome fuel cell/pump install
fair play nice rear end
Originally Posted by Kelv
Mark, thats quite nice seeing your setup.
im about to have a tank made for mine and thats given me some nice ideas as to how to lay it all out etc.
although it is a little over complicated i think, this was due to trial and eventually removalof a lift pump, i am considering losing the swirl pot and running the 044 pumps parralell straight to the fuel rail then straight back to cell, losing the swirl pot as the tank is foam filled...BUT....it works fine so why fcuk with it ay
Bit like spending 1k on getting your car professionally valeted top to bottom inside and out and then making a thread entitled "just cleaned the car lets see yours"
because your bored
The battery needs to be clamped inside the battery box securely.Just using the battery box lid to stop the battery from flying out in an accident is a very amature way of fitting the battery,not to mention downright dangerous!!Regards,Micky
Not being picky but i am planning on mounting mine behind the passenger seat on the floor, as imo its low down and cant really go anywhere in an accident as its right behind the seat
Is it fiberglass or ABS plastic ? Wet or Gel battery ?
I would only ever put a gel type battery inside a car cockpit and these can be mounted safely upside down or on their side etc and even without any box whatsoever if you wish.
If the unfortunate should happen then having acid dripping down onto you when upside down is not nice feeling.
As for position its mounted within the safety zone of inside the roll cage so thats the safest place to be
My gel battery is on its side behind the seat
And if you are after good strong advice Mark I'd lift those seat belt mounting points up if you can, by fitting a proper rear brace and restraining from that. If your worried about having such a big accident that the battery box may split then where those belts are pulling from they will do basically nothing.
Re: show us your secure battery trays/boxes
il get that sorted then before the next outing
As for the gel battery's......ive been looking at the likes of a red top/yellow top optima type as they are dry cell and can be mounted anywhere/any position, yours looks good but looks a little small and as my car sits for long periods with no tricle charge etc i need something to last as long as possable to keep my alarm going and good cranking after being dormant for several weeks at a time, ive seen people use these little race batteries and they have to jump the car every 5 minutes to start it
whats your experiances on this matter
Sponsor
just found these as i need something safe for mine
http://www.hamiltonclassic.co.uk/Pro...eryOdyssey.htm
Originally Posted by BillyCabrio
Marc what about one of theose batteries like DaveEscos had in his cossie?
Was yellow and grey and a funny shape
I know thats not much help, but they could be mounted vertical or horizontal and are of normal 12v size.
How long is long periods ? I have 2 and keep one on the car and the other permanently conditioned with a mobile phone charger plugged into a solar panel cell. (Costs nothing to keep topped up that way). These type of batteries much prefer a trickle charge to a boost as that can sometimes kill them, so the few milli amps from a phone charger is safe and fine over long periods. (2/3 years lol)
We often have them in stock second hand for about 40 quid each.
Sold a few to the pug lads so maybe Spiky or Phil can offer more advice as their track cars may also be laid up for longish periods ?
The very small ones your on about are mostly used in single seater racing, the engine is jump started from a slave battery then runs off power from the alternator and a tiny 12v gel pack. Not recommended for your application.
Pic below was one of our secondhand units and is shown so you can see the full size, ignore the label lol it went a long time ago now
Good news on the cage front then Nothing wrong with that OMP jobbie now in a track car except the bolts are in upside down but as its coming out then that dont matter
The change over to weld in cage is due to the fact ive ever had the strengthening plates in the floor like your supposed to as to be honest at the time i fitted it i never knew you were meant to as i bought the cage second hand and thought you just bolt em in, its been bugging me ever since i found out so thought what the heck...may as well fit a full weld in jobby as some say they provide 50% more stiffness over a bolt in.
as for the battery, i have no power at my garage, nor can i use a solar charger etc for fear of the kids findning it breaking it the little fookers.
The car will sometimes stand 4-8 weeks without being started and driven.
How the posts are is irrespective other than you need to change your cable ends to suit. Its like saying why do some wet cell battries have square posts and some round ? Its just a design. Very few have a female connection on top, the majority of that size of gel batteries are M6 male as shown above.
Dont know the curent draw from your alarm, but I'd guess over that sort of period they would be ok. If you do begin to expeience problems then using or connecting one of those portable battery jumper packs that are in many shops now would only take 30 seconds or so.
Good news re the cage then Shows your seriously thinking about safety Its all about minimising risk at the end of the day, and a non drip gel battery inside a cockpit is just part of that risk removal.
If you have to put up with a jump start once or twice a year thats going to be better than any of the dangers from tipping over a wet cell.
Safety is never ending mate, no one is trying to give you chapter and verse, its your car and at the end of the day you choose what you want to do with it
as you said the bolts are in upside down
Come on Mark this is me your talking to!!
I didnt think you did cant afford!
They will put a welded cage in for around £900. I am in Shrops at the moment but when I get back we could take a journey up there for a chat/quote if you fancy. Dont forget mine was costly because of all the suspension work and extra shit I had added.
sooner rather than later tho mate as adrenalin are kind of holding a booking in date for me
I am back on the 2nd of Jan so we could pop up on the 3rd, failing that |I can PM you the number and ask for Gordon tell him i sent you.
Hes a nice bloke. But when you see what they can do I bet you will be spending more! LOL
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
