cars boost spiking after 3-3.5k ???
one minute car boosts up fine, next min @around 3k boost will cut? all boost pipes etc seem fine, any ideas? thank you
i thought it was over boosting first of all but appears its not as ive turned boost completly down on bleed valve inside car and still does it, 1 min its fine next it cuts @ 3k ive got boost set to 0.8 of a bar
boost gauge is all over the place, revs are around 3k and will cut boost, and then next over times it will be perfect and hold 0.8 bar nice in 4th and 5th and boost might not even be hitting 0.6
just curious could cps have anything to do with it? it ouldnt start before due to weak spark so my sisters bf who is mechanic investigated and found a break in the cps cable, repaired that and it started?
Originally Posted by MK5RST
Total diferent kettle of fish... Yeah, i would try a new CPS to start with pal because they send a signal and repairs can make them go funny
was out in the car earlier, one minute the car was fine, had it driving fine for half hour, then not boosting over 0.3 bar then once started again boosted fine for around 20miles?
CabrioTurbo
01-08-2015 11:04 AM
Escortdriver1
31-07-2015 02:36 PM
