Stack Dash arrangements
Old Dec 20, 2007 | 05:23 PM
Kelv's Avatar
Kelv
Almost there!
Default Stack Dash arrangements
can i have a peek at peoples stack dash set-up's please.
after ideas and inspiration for what to do as im stuck at the moment wether to go for the usual triangular style stack or the 80mm style.
dont want conflicting colour arrangements or or anything looking out of place.
i love how Martoon's and Porkies are but down side is all my Defi's are white and the Stack boost gauge etc is black.
or alternatively Rainbird style but then over kill with the extra features repeating most of what the defi's display already.
dont you just hate wasting money
Old Dec 20, 2007 | 05:38 PM
NEIL A's Avatar
NEIL A
No pics yet kelv as im still getting bits together, but im planning on 80mm boost gauge then the original fuel and water at the top in the middle with a stack rev/speedo on the left, with the original idiot lights fitted around. Just trying to get a spare set of clocks so i can get the elecs at work have a play with them. Im using white faced gauges so should fit in with the original two.
Old Dec 20, 2007 | 05:44 PM
Kelv's Avatar
Kelv
Almost there!
i like your idea's Neil, could work well when completed
i was kind of thinking of the two 80mm round ones, Mike can do me the 80mm boost gauge but then that means ill have to get them all in black, and clashes with the white defi's in the centre panel.
Now more thinking of a single 80mm in white and two gauges either side of it, maybe my 60mm Apexi boost but then its sourcing something else to match up with it, lol - maybe a Defi fuel presure unless i could source an Apexi Fuel P to match the Boost.
Old Dec 20, 2007 | 05:49 PM
M K's Avatar
M K
i know its not a cossie dash but still.............
NEIL A's Avatar
NEIL A
sounds good i got that white elliot 3 bar gauge coming then going for a 10k stack with speedo. There is another idea i want to try for the backing but will wait and see how it works out first .
Old Dec 20, 2007 | 05:52 PM
Kelv's Avatar
Kelv
Almost there!
Cheers Marc.
doesnt need to be a cossie dash, just after idea's of how to lay it all out.
cheers for yours, looks real nice
Old Dec 20, 2007 | 06:46 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Hi Kelv
I was in the same situation as you as i have 6 Defi's that do everything but my Speedo, rev counter and fuel guage are fcuked and as i didnt need all the stack features i was going to have just a Single 80mm style one with a seperate fuel guage
But to be honest for an extra whatever it is the basic Full stack isnt much more and you can still use things like the oil temp but for say your gearbox oil insted of the engine
I also have a water temp Defi that is before the water is cooled and the one that is on the dash is after its cooled so that can be used on the stack to keep 2 readings, before and after
not sure what model mine is but Goldbum will be able to tell you
hope that helps
Old Dec 20, 2007 | 06:55 PM
kjc300's Avatar
kjc300
Stack + EGT and Boost
Although if I source another apexi el 1 gauge (maybe oil/water temp) I'd like to put the boost back in the A pillar pod
The stack does everything else
Have afr gauge in the clock!!
Need to find something for the centre pod now though, as I'm not sure I can be arsed to wire an inverter up to it so it lights up!!
Old Dec 20, 2007 | 07:22 PM
Kelv's Avatar
Kelv
Almost there!
Ben, i like the idea of monitoring gearbox etc - i hadnt even thought of that.
im the same already with the Defi's, Defi water is tapped into bottom of swirl pot, where as the pectel shows whats being read at the back of the head, was going to then get the stack water on the leading side of the thermostat aswell, 3 monitored points.
oil temp defi is in the sump and with your idea the stak could cover the gearbox maybe
talking away, Ben youve helped me make up my mind on exactly what im going for, more Rainbird pestering, but atleast hes about to get paid for it
Old Dec 20, 2007 | 07:25 PM
Kelv's Avatar
Kelv
Almost there!
Kev, Pectel monitor in the banana pod will be a good thing to source if you ever fancied it, or found one.
Old Dec 20, 2007 | 07:33 PM
Kelv's Avatar
Kelv
Almost there!
Must admit thats something id have over looked aswell Dave.
must be a way around it.
Old Dec 20, 2007 | 07:39 PM
Dan's Avatar
Dan
This is Jasesapphy's in his 2wd Saph Kelv
Old Dec 20, 2007 | 07:40 PM
Kelv's Avatar
Kelv
Almost there!
that looks soooo familiar
Old Dec 20, 2007 | 07:43 PM
kjc300's Avatar
kjc300
There is!!
Get the inverter from RS components (part number on here somewhere!!) and wire to the old 'lights on' circuit and then plug the centre pod back in
Old Dec 20, 2007 | 07:54 PM
Bullett's Avatar
Bullett
damn dont you just hate being jealous they are all so nice looking.i want one.
Old Dec 20, 2007 | 08:07 PM
Kelv's Avatar
Kelv
Almost there!
Neil, you can look at mine when its done if you want mate
Old Dec 20, 2007 | 08:14 PM
kjc300's Avatar
kjc300
Ref inverter bits and bobs - I found the thread - I'll start a new post in 'escort cosworth'
Old Dec 20, 2007 | 08:17 PM
Bullett's Avatar
Bullett
from the passenger seat on a track?
still makes me want one.
Kelv's Avatar
Kelv
Almost there!
Moving on a bit now, what options are there for the idiot lights?
what choices and styles etc!?
Old Dec 20, 2007 | 08:27 PM
kjc300's Avatar
kjc300
I'm sure there's a few but you have.....
The bright 6 unit from demon tweeks or wherever,
Rainbird stylee
or be adventurous and jiggle the standard ones around like myself and I think Paul did.
Old Dec 20, 2007 | 09:15 PM
Dan's Avatar
Dan
Pmsl I forgot where it came from mate!
Old Dec 21, 2007 | 01:08 AM
Gatecrasher
Not welcome...
pleased to be of some assitance
ohh and thanks for te heads up on the 3rd water point for the secs monitor when i get time to get one and get it fitted
Old Dec 21, 2007 | 09:02 AM
lamb chops's Avatar
lamb chops
Wow they look great!! Me want
Old Dec 21, 2007 | 09:26 AM
Franco's Avatar
Franco
I'd go for a Martin / Porkie set-up..............But then thats not ever going to happen now Stack pulled the plug on the boost gauge!
Old Dec 21, 2007 | 10:06 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
They've brought another one out haven't they?
Old Dec 21, 2007 | 10:30 AM
Franco's Avatar
Franco
I bloody hope so Rad!............
Martin mentioned it a while ago but the trail went dead I think. Jap markets killing us boost junkies (poxy 2bar max! ).
Old Dec 21, 2007 | 10:45 AM
Charlie Chalk
Unknown.
Someone has posted a picture in the Resto room, Don't know what size they are, but it was defo a Stack boost gauge!
Old Dec 21, 2007 | 10:57 AM
Franco's Avatar
Franco
That was some pikey looking thing Richie (B9KOS) found
I'd rather fit a TIM gauge!
Old Dec 21, 2007 | 10:59 AM
Franco's Avatar
Franco
Originally Posted by B9KOS
How about a 2.5 bar 80mm one. Only £130
It matches his car................
TACKY!
Old Dec 21, 2007 | 11:35 AM
Rick's Avatar
Rick
I have defi's and in white. I am very fussy for making sure everything matches. The boost gauge is a HKS 2.5bar, which matches the defi's almost perfectly....
Old Dec 21, 2007 | 11:37 AM
Franco's Avatar
Franco
Is that 60mm Rick?!?!?!
Where'd you get that?
Old Dec 21, 2007 | 11:39 AM
Charlie Chalk
Unknown.
The 60mm HKS Gauge shop at a guess
Old Dec 21, 2007 | 11:40 AM
Franco's Avatar
Franco
See..............Tosser!
Mark RS
Oct 12, 2015 06:01 AM
Fordmad!
Sep 29, 2015 07:03 PM
Mc5506
Sep 29, 2015 09:06 AM
IainRS1700T
Sep 25, 2015 06:44 AM
