Ford 6000 CD
Legend
No, I just pulled one out of a late Mk1 focus and had a look for you.
Just the normal inputs plus the one for steering wheel/module control.
Got a 6006 in another car somewhere, will have a look at that as well when I've done a poo.
Resident Wrestling Legend
is it the earlier round ones you want to put into the later square holes?
they won't fit and there are several different dash facia's depending on which unit you are fitting
for example, the sony head unit has a specific design and you need the sony designed fasia bit to get it to fit properly as the supporting brackts at the back don't line up and foul the wiring etc
you also need to make sure you get a head unit from a C max as some different units won't be copatablie with your facias either
and some have a plug in the back that is a basic headphone jack to plug the ipod into, but again, this lead may or may not be there and it may or may not work with all the different models
borboyous
22-08-2015 11:17 AM
