2wd saff head gasket gone!!!!!
,as above did track day sunday and my head gasket let go at 24 lb boost the temp gauge never went above half but steam coming out of cap ...hoses hard etc ...engine was rebuilt 6 k ago ..now running t38 greys etc ... should i put yb611 group a gasket with ford bolts on next ???? not sure what it had on in first place ....will this gasket hold 28 or so lb boost every one keeps telling me diffrent things... helpfull input welcome ....cheers jeff
I had the gasket in question on my 3dr with 33psi and all was, still is good on the car i believe, my block was wire rung though..
Make sure you've got nice surfaces when you replace it..
Defo wants a skim, clean block with old knackered emery paper around a steel bar.
Best to use ARP stud and nut kit, will take this boost all day long no problems.
It will work correctly IF you rest the gasket as you fit it otherwise it may not.
my group a gasket on a wire rung block has never failed even at 2.5 bar.
Originally Posted by mechanic28
mines weeping down the block as well fella but i cant be bothered with her anymore its too expensive to do cant spend anymore pennies on her
i think its 3 door time for me had her for 7 yeras now how much was your gaskets all together???just make sure they got the correct numbers as posted further up chap
no chap i can only use coopers head gasket due to the block being machained to except the fire rings on the headgasket
dojj
28
11-09-2015 10:00 PM
