..i need some DIY advice
.....i have a new conservatory with just a concrete base and i want to sticky floor type tiles down..do i stick them straight to concrete or is there someting i have to put down first??????
Re: ..i need some DIY advice
I though heated marble or lime stone would be more your style!
Maybe it is an MR2
Originally Posted by Graham S1
paint over a thin layer of pva and water mix. not sure of the correct mix ratio off hand.
the directions should be on the side of it for the ratios for the different applications
As above, this will seal the floor and prevent the tiles sticking to the dust rather than the floor.
You could always lightly spray carpet adhesive spray down as you do it ofr extra stick..
Flooring like Karndean (sp) need special glues and carefull application, boggo tiles should be a doddle.
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
