Internet Explorer settings? cant connect?!
Got this Johnny...
But, Im not "offline" , I've checked the settings?!
done a test thing and no problems came up, said my internet connection is fine
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
What you can try:
Diagnose Connection Problems
More information
This problem can be caused by a variety of issues, including:
Internet connectivity has been lost.
The website is temporarily unavailable.
The Domain Name Server (DNS) is not reachable.
The Domain Name Server (DNS) does not have a listing for the website's domain.
If this is an HTTPS (secure) address, click Tools, click Internet Options, click Advanced, and check to be sure the SSL and TLS protocols are enabled under the security section.
For offline users
You can still view subscribed feeds and some recently viewed webpages.
To view subscribed feeds
Click the Favorites Center button , click Feeds, and then click the feed you want to view.
To view recently visited webpages (might not work on all pages)
Click Tools , and then click Work Offline.
Click the Favorites Center button , click History, and then click the page you want to view.
Most likely causes:
What you can try:
More information
For offline users
goto to you run command and type cmd
a block box will show up
type ping www.google.com (return)
at the same time type ipconfig (return)
right its IE
check in setting if its not one line, in settings
somtimes programs think you have a proxie server and add a proxie address
internet setting connections, proxie settings, non of the tick boxes should be checked
Sorry mate im confused
All I get when I go into settings is this...
As for firefox, I dont like the layout, and dont need it, I use AOL and have no problems with it.... Its just my Winamp aint playing because my IE aint connecting
Just comes up with this on the Media Libary
Sorry :
The media library feature you are attempting to use requires an internet connection. Please make sure you are connected to the internet and try again.
Originally Posted by taken from WINAMP Forums
In Winamp, try the following
Ctrl+P > General Preferences > make sure 'Internet Connection Settings' correctly reflects your internet connection.
In Windows Internet Explorer, try the following
Tools > Internet Options... > Security tab > Trusted Sites icon > Sites... button > add *.winamp.com and *.shoutcast.com to the list.
To be sure the above changes fully take place, close Explorer, Winamp, Windows and reboot the computer.
also, you could try cmd
ipconfig /release
then ipconfg /renew
or you could try
start---> control panel--> network
then the uper left corner --->file ---> new connection then follow the wizard
ipconfig /release
then ipconfg /renew
or you could try
also go to sec and click on restore default
