can some one help with my rev counter?
hi all
i have a 1.1 pov spec mk3 with no ecu (!)
im waiting on a 2.0 but for the time being im having fun with what i have. i got a rev counter for free of my friend and wired it up, but it onl gives out half readings?
heres a pic
its wired into the green wire second in on the left, the wire which would be for the rev counter if i have one (!)
any ideas?
thanks in advance
matt
heres a pic
any ideas?
thanks in advance
matt
Its because (and i am just assuming this bit) the rev counter you have is for a coil not coil pack and is not suitable for a edis bassed system so what you need to do is this;
And that should get you a proper reading
Fast Ford snapper
My brain wants to melt when I look at wiring diagrams
Yeh there diodes that you install onto the coil pack wires that then give you the right signal for the rev counter to work properly.
Look in maplins or somewhere similar and you should be able to get them
Originally Posted by mk3matt
cheers, so by joining the 2 green wires it should double the output? not cancel it out no?
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
JoeyBoyden
18-08-2015 05:56 PM
cozzy jeff
14-08-2015 05:46 PM
