General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
From memory, the top ones goes to the cam cover. Turn the cam cover over and there is an outline of a circle to drill using a 5/8" drill bit. The one on the left goes to the blanking plate on the block under the exhaust manifold about 1.75" from the bottom on the turbo side. The right one goes to the existing breather under the inlet manifold - remove all the parts. Leaving the bottom one to go to into the chassis leg. Assuming you are not using a catch tank.
