Fiesta Si quick engine change?
Right how quick do you recon i could put my Fiesta Rs1800 engine into my fiesta si? it should be a straight swap whats the adverage time to do this in?
I should be able to use the 1.6 wireing loom wont i?
ive also seen people change engines without taking wheels of.. how do you do this
basicly i need to change it in a weekend. its possible imo..
whats the adverage time for this?
matty
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
matty
STOP!... Carry on
it took me and a mate 2 days (minus rebuild & gathering time) to change his escort from a 1.3 to 1.8... so i suppose it could be done if you get it all together and someone who knows whats going on!
Depending on how good with a set of spaners you are should take no more than a day.
Not sure on loom but it should be ok.
Wheels will need to come of so you can take the drive shafts out the box if your going to take the whole lot out.
Just taking the engine can be a pain in the arse depends on how you feel.
If it was me i would be taking both out and swapping the box over and back in.
xr2i-carl im good with tools ive done it before just never in a rush as im in work monday lol.
im basicly putting the 1.8 out of my escort project (see sig) and sticking it in my fiesta
i have the ecu out of my scort so that wont be a problem. just wonderd how quick people can do it
iirc, and ive just had this argument with my mates, as were both doing 2.0 engine conversions into a si,
ive got the right ecu, a 2.0 desk one,
hes got a rs1800
now, i reckon his wont work, as the law of the conversion says, you have to use a ecu with the prefix desk (if itsf from a 2.0 mondy)
i dont no any one whos used a rs1800 engine with a fiesta si loom
is your ecu external pats, if so, it wont work straight away, also is internal or external edis, it must be exturnal, other wise, again it wont work
conversion is piss easy as yours is already a 1.8, so has correct water pump and sump,
easily do able in a day,
we plan to do both of ours, including swapping the ancilirys over in a weekend.
hope this helps
hes got a rs1800
hope this helps
mk3 and mk3.5 fiestas are completely different,
then the mk3.5 xr2i have different looms to the si,
like i said, itsall to do with;
whether the car your getting the ecu from has internal or external pats (pats is the sercurity system)
and whether it has internal (inside the ecu) or external (out side the ecu) edis (electronic distributerless ignition system)
the si has external pats, internal edis, so as long as your ecu is of this configuration then it mightbe ok,
go on www.fiesta-si.com there is a guid and a ecu pin diagram
some zetec models have the igintion and injector pins in different places.
lee
lee
RS1800 into a 1.6 Si is straight swap with the right RS1800 ecu. This is what i had before my tuned 2.0.
Reckon you could you doit in a weekend easily as its basically plug and play
JoeyBoyden
04-01-2024 02:36 PM
JoeyBoyden
18-08-2015 05:56 PM
lockie
31-07-2015 10:03 PM
