Black Top Zetec in mk3 Escort
not too sure on the differences between the silver tops and black tops but this site is pretty useful when sticking zetecs when cvh's used to live
http://www.quantums.info
TOMMY_TURBO (30-12-2015)
Originally Posted by Gordon1
what gearbox you thinking of putting in
Originally Posted by beefy-rst-2
hows the viper coming along mark ?
the black top head will bolt to the silver top but the timimg belt will not go on
i would use the black top as is not hard at all to fit
i have put them in mk 4 mk 6 escorts and mk3 fiesta
That wil be cool mate
I take it the engine mount bolts up the same as the silver top zetec?
Is the 2.0 flywheel the same as the silver top too? In other words do i ned a 1.8 flywheel
Thanks
Thanks
Engine mounts are all the same. You'll need to use a 1.8 sump and pick up (so the exhaust clears), and a 1.8 flywheel if u want to use the mk3/4 box. The head needs retapping for the cvh thermostat housing. Water pump wise, i'm going to use an electric one. Engine mount is the same.
All the black top sumps are the same you only change the sump for a silver top zetec.
Just wondering why your going to use the cvh thermostat housing too?
to a 1.8 silver top, not 2.0 silver top sump...
I was led to beleive the hoses were differemt, using a cvh stat housing means direct fit of coolant hoses.
I'm using the black top engine mate not the silver one and as far as im aware you can use the zetec stat housing without issues its what i used when i fitted a silver top last time your right about using the 1.8 sump on a silver top but all the black tops have the same sump if i remember correctly
im using a black top too - my point is u cant use the black top sump - u need the silver top 1.8
When my donor engine arrives i'll be able to figure it all out!
