? Which Aeromotive fuel regulator ?
Needing to buy a fuel regulator for the zetec T build as the inlet /fuel rail assembly will not take the standard Rst one i have.
Running 4-500bhp so a cosworth one will be a good match, has anyone a model name/ number.
I would not use one as 50% of them I have seen have had problems ranging from leak air through the nipple and leaking out top thread, also fuel pressure dropping off on boost.
Mark
Mark
I use a weber alpha unit from demon tweeks, it is not adjustable but you can buy different pressure caps 3.0bar, 3.5bar ect.
Works fine, but it not very bling!
Simon.
Simon.
Mark
Mark
Nicks car is almost getting there, be good to see it finally running.
Simon.
Simon.
Id function over fashion anyday.... what pressure one are you uisng
cheers
Simon.
Simon.
cheers
S.
Mark
Mark
Mark
Si is that with the 750cc injectors still or have you upped those too.
Im thinking at the mo my spec is suited to 750cc with the power i intent to use.
S.
