Shot blasting...
Anyone know where i can get a d.i.y Shot blasting kit.
I'll be using it on my compressor and ive seen the obvious ones like sealey etc..
Just wondering if anyone has a kit themselfs or knows of a good one to go for.
It would make life so much easier with a proper bit of kit.
ive looked but for a cabnet of a decent size 2 get anything bigger than a brake disk your talking lots of cash (200-300)
The gun on its own is the cheep bit, but its if u got some were u can be spraying grit everywere! and of corse not bottered about only using the grit stuff once!
True though it would make life so much easer, no more wire wheels
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
make your own its easy to do
buy the gun and glass bead from machine mart then make a tall wooden box like a wardrobe, sheet of glass in the front or top, 2 holes for rubber gauntlets in the front, and a hopper type catcher inside to recirculate the bead back to the gun.
I have made a couple over the years, its a handy piece of kit, if you put thin plastic sheet in front of the glass it stops it misting over as well, just replace the plastic every so often
If you only have single phase [240 volts] buy the biggest compressor you can ie 3 hp decent size air tank say 200litres because any shot blaster uses a hell of a lot of air and a little cheapo sealy or machine mart special will not last to long.You can buy 4hp compressors that run on 240volts for about 5 or 6 hundred quid but you cant run them of a 13 amp plug you need a proper supply like a cooker sockets that is 30amps
You do need a very large compressor, I have a 4hp unit and 80-litre tank, and this is only just capable for the job, well for any length of time anyway ![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Steve
Steve
Originally Posted by jr
is there anything machine mart etc sell thats 240v that would be ok for the smaller blast cabinets ?
cheers for the help btw
to be honest mate just buy the biggest machine you can afford but even then i bet it struggles.Buy one where the pump has cast iron barrels not aluminium as these tend to be more heavy duty
Originally Posted by Christian and Beccy
We have an SB30 here as in the first link that GarethT put up. It's hardly been used (just as I told Gary, but he wouldn't listen).
We'd be interested in selling it if its any use to you.
got a sealy one works spot on for small stuff cam covers etc etc screen gets fucked easily but thats not a problem. get a second hand one and youl save loads on what youd pay for someone else to do it for you
Originally Posted by NEEDFORSPEED
got a sealy one works spot on for small stuff cam covers etc etc screen gets fucked easily but thats not a problem. get a second hand one and youl save loads on what youd pay for someone else to do it for you ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Originally Posted by nobby20
Ive got a shot blaster and i just use kiln dried sharp sand when blasting rust etc. Alot cheaper than using the proper grit. Its about 5 quid for 25 kg. Dont mind it going all over then. ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Rod-Tarry
237
18-03-2016 09:13 PM
