F.A.O MSD STU or anyone else into PS3's
I read a post a while back about being able to stream video's etc from a PC onto your PS3, if you have time would you be able to explain to me how this is done. My PS3 is connected to the internet etc and I have some DVD's downloaded on my laptop that I would like to stream onto my TV via the PS3.
Cheers in advance.
Nick.
Cheers in advance.
Nick.
Chasing Radders
I know its not the PS3 but the Xbox 360 does the same...i have just set this up on mine, just means hardwiring it in
I had to upgrade to a different program ..ie Windows Vista.....then just connected it to the console and job done
I can now watch the hundreds of Full HD films i have on my hard drives through the Xbox and onto my TV
On the PS3 options there is a menu to connect to a media server so I presume it is something to do with that. My laptop is on vista, i'd prefer to use the PS3 rather than the xbox as thats not connected to the surround sound properly.
Ex Full Price gold member
Testing the future
Go to "Video" and select "Media Servers". This will search your network and hopefully find your PC. It will show all files, but you have to allow on your PC to share files. Type in "Share Files" on Windows Vista Help to find out how...
Both XB360 and the PS3 do not run all video and sound files. Neither do AVI and XB360 works better with Windows Media Player.
Testing the future
just googled 'playstation 3 manual' and came to:
http://manuals.playstation.net/docum...ent/index.html
type media server in the search and click the first link to get this
http://manuals.playstation.net/docum...nnectdlna.html
the bit that you probably need to do is
hope that helps nick
When using a MicrosoftŽ WindowsŽ personal computer as a DLNA Media Server
A MicrosoftŽ WindowsŽ personal computer can be used as a DLNA Media Server by using Windows MediaŽ Player 11 functions.
1.
Start Windows MediaŽ Player 11.
2.
Select [Media Sharing] from the [Library] menu.
3.
Check [Share media].
4.
From the list of devices under the [Share media] checkbox, select the devices that you want to share data with, and then select [Allow].
5.
Select [OK].
Setup for the DLNA Media Server is completed.
1.
2.
3.
4.
5.
Select [OK].
1.
2.
3.
4.
5.
Select [OK].
1.
2.
3.
4.
5.
Select [OK].
Testing the future
as i say, i don't have one yet so can't really help more than that.
you, or others, may be interested to know that you do not need to run a pc to store all your media on. a pc uses a lot of energy and makes noise etc. there are things called NAS (Network Attached Storage) that can do the job for you.
i have a NAS (hidden away in the cupboard under the stairs) made by QNAP that is basically a hard drive in a case with a network connection (hard wired to my router) and it also has a small cpu and memory that can run an operating system. you can then set it up to act as a Media Server for PS3 or other devices capable of streaming from a media server (i'm shortly going to get a hifi for the bedroom with built in wireless streaming capability)
this link may also help with your current problem
http://www.qnap.com/images/products/.../TS109AP08.htm
EDIT: a NAS is also a good way of keeping a backup of all your important media files rather than simply using a USB HDD or whatever
Originally Posted by silky16v
just shared mine works perfect just followed the windows media player share and it found my PS3
JK12
33
26-04-2021 12:09 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
