MLR Rolling road today......477 bhp...Graph added.
Old 18-11-2007, 08:24 PM
  #161
Tangodeltasierra3
Tangodeltasierra3's Avatar
Originally Posted by Karl
Dave,
Seriously Dave, from mapping your car and knowing that the engine can out run the greys when running over 28psi, I think a good estimate of engine power is around 420bhp @ 28psi.
Unless its an error in the exhaust sampling, the AFR is leaning off quickly as the revs rise, indicating that you have reached the maximum duration time of the greys. As said for now turn the boost down to no higher than 28psi, as this is the maximum I was able to map the car to. Above 28psi it started to lean off after 5500rpm.
If you're interested I can simply remap the car on some 750cc injectors and a 5 bar map sensor if you want to ensure reliability at higher boost levels.
Taxi for Daves chequebook
Old 18-11-2007, 08:29 PM
  #162
dave cos4x4
dave cos4x4's Avatar
Karl
400-420 is well enough for me Karl,well happy with that
think i will save the 5 bar and 750cc's for the escort mk.2.
don't need the escort cos to have any more mods,well,not meaning more power,safer mods yes but then again i could just turn it down a bit more as it will be a second car when the mk.2 is finished.
Old 18-11-2007, 08:30 PM
  #163
dave cos4x4
Tangodeltasierra3
no cheques left in there Craig.
thank fook.
Old 18-11-2007, 08:42 PM
  #164
Jay,
Sponsor
Jay,'s Avatar
L8 ECU
Doug.
he did say about it and said about the intake temps etc...they were a bit high.
Jay also has said exactly the same as you about the afr being high,hence more power etc..
thanks Doug.
as said on the phone dave lean extra 3psi on top would force the figures up , but still a bit of a mystery on how a standard head managed it lol
oh and remember no 150mph private road racing until you get that top end fuel sorted
Old 18-11-2007, 08:53 PM
  #165
tracktoy
tracktoy's Avatar
result dave
good figure whatever it is bud
Old 18-11-2007, 09:16 PM
  #166
leecavturbo
leecavturbo's Avatar
Dave you really should have a wideband in there
to protect ya pistons.
but i can't talk as i need one too
egt would be nice too ŁŁŁŁŁ
  #167
lamb chops
lamb chops's Avatar
Bloody good result at 420 for a standard engine I want some of that!!
Old 18-11-2007, 09:21 PM
  #168
dave cos4x4
jay.
3dr-rally-slag
thanks Paul.
leecavturbo
i know,but got a better car to spend money on.
lamb chops
big turbo,big injectors...
thanks for everyones input tonight( excepts Pete's ),been very intresting.
Old 18-11-2007, 09:31 PM
  #169
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Pete's just jealous Dave lol
Good result what ever the true power is
Steve.
Old 18-11-2007, 09:34 PM
  #170
dave cos4x4
lol, he's a top bloke really,well most times
thanks Steve.
Old 18-11-2007, 09:44 PM
  #171
Fiecos Dan
Fiecos Dan's Avatar
I'm sure 430-440 bhp was seen in the 80's on std RS500's, with just a remap for the 8 inj's.
Old 18-11-2007, 09:58 PM
  #172
Tangodeltasierra3
Some more piccys from today too
https://passionford.com/forum/viewtopic.php?t=302259
Old 18-11-2007, 11:02 PM
  #174
dave cos4x4
Matt J
well the same as Mr.Ford made it.
Old 18-11-2007, 11:07 PM
  #175
JonnyBravo
JonnyBravo's Avatar
Here's the link regarding the setup on the DD rollers.
Its about half way down on page 1 where "Pat" talks about how it operates.
http://bbs.22b.com/cgi-bin/ultimateb...9;t=001353;p=1
Edited as Dave replied above
  #176
JC
JC's Avatar
bog standard as we built it
standard bore ,standard head ,standard cams ,standard crank etc
just non standard right foot and non standard driver
due to disbelief cosworth did now what they where doing
Old 18-11-2007, 11:11 PM
  #177
dave cos4x4
JC
tried calling you earlier.
Old 19-11-2007, 12:10 AM
  #178
Jay,
Sponsor
Jay,'s Avatar
that must be a capped boost and about as much a standard head will cope with?
Old 19-11-2007, 12:53 AM
  #179
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
Originally Posted by Mark Shead
Mark Shead
still 'no comprehenday Mark'
have i got 400 bhp,that will do me.
Easy way to explain you dont have 477hp but you do have a lot anyway .
Mark
Dave- top figures
mark- also now means i'm tempted to bolt on a GT30 onto my stock motor for more grunt ...
out of interest what HG you using dave and also MARK what sort of strain would this put on a stock motor ie std head etc as i thought the head culdn't cope with this power wihout being ported slightly????
Ad
Old 19-11-2007, 05:40 AM
  #180
dave cos4x4
adamski frst
thanks Adam,
i am using a Comtic multi-layer gasket.
Old 19-11-2007, 06:29 AM
  #181
Spiky
Spiky's Avatar
good result
400-420 on std engine and t4 is great mind
Old 19-11-2007, 08:30 AM
  #182
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Dingly,
APTs set up has the temp probe measuring the cell temperature and NOT the airbox temp (which as Mark has pointed out, gives hugely (upwardly)corrected figures) .
Old 19-11-2007, 09:20 AM
  #183
Toymota
cossie_mikes biatch
Toymota's Avatar
well in on the power figure dave! i fookin love your escos and it goes round track like nothing ive ever been in!
sorry me and mike forgot to come! lol
Old 19-11-2007, 09:58 AM
  #184
Dingy
Dingy's Avatar
Dingly,
BUT you said they were all accurate.....
Old 19-11-2007, 10:01 AM
  #185
Magic Numbers
Magic Numbers's Avatar
What wheels are on that Yellow Evo? They look fooking nice
Dave - Nice power figures
Old 19-11-2007, 11:52 AM
  #186
Staffi
Staffi's Avatar
Afternoon Dave
Old 19-11-2007, 12:00 PM
  #187
Mike Rainbird
Caraholic
Originally Posted by dingy
Dingly,
Where this method of measuring temps is NOT employed, otherwise it's as wank as engine dynos with cell temp measurement too close to the engine (for the exact same over correction reason ) .
Old 19-11-2007, 12:47 PM
  #188
Tangodeltasierra3
BBS Challenge
Old 19-11-2007, 01:48 PM
  #189
Magic Numbers
BBS Challenge
What size and did you need to fit spacers?
Old 19-11-2007, 04:14 PM
  #191
dave cos4x4
Matt J
not that i know of Matt.
deffo is not a modded head.
Afternoon Pete.
Old 19-11-2007, 04:46 PM
  #193
Kev.H
Kev.H's Avatar
Dingly,
so Mike ive run on APT's DD your saying it overreads Hows comes I only made 270 You mean i might have even less Yet I can make more on say the track n road TAT single roller 285bhp ? Which is meant to be very accurate 1,5% within a SUN engine dyno
rolling roads are sooo confusing
Old 19-11-2007, 04:54 PM
  #194
Nash
Cake lover!
Nash's Avatar
Dingly,
Kev i suggest you read Mikes bit again. He isnt saying it over reads at all. APT keep the temp probe out of the engine bay which stops it sucking in heat from the engine. This stops the computer over correcting the figures and give a more accurate figure.
  #195
dave cos4x4
Matt J
are you sure the exhaust housing is the same size as everyones.
mines bigger than a .63.
its a standard rebuild Matt if all goes wrong with it , with the power i roughly have...400-420 lol, then why bother with the money mods and when something goes wrong it then cots a fortune to get a standard engine to the spec you have been used to.
i'm happy with the spec anyway.
Old 19-11-2007, 04:59 PM
  #196
dave cos4x4
So where i did mine,they would have been better not putting the temp sensor in the air filter....where would they have put it then that would make the rolling road safe.
they did say that the evos were better suited,as Mark said also.
Old 19-11-2007, 05:04 PM
  #197
Tangodeltasierra3
Dave yer kicked Ass mate so fuck em lol
Old 19-11-2007, 05:07 PM
  #198
dave cos4x4
pmsl!
cheated.
Old 19-11-2007, 05:10 PM
  #199
Nash
Cake lover!
Nash's Avatar
Just clearing up what Mike put thats all mate.
I think APT just have the sensor hanging up in the Booth so it just reads the Air Temp. If its to close to the filter it will pull the heat in from the engine, this will make the computer think the air is hotter than it is. Then it will over correct the readings.
Thats how i understand it anyway mate, might be totally wrong.
Quick Reply: MLR Rolling road today......477 bhp...Graph added.
