PF plumbers..... shower pump question ?
Do I have to fit the shower pump in the airing cupboard and pipe to the shower from there or can I just Tee into the 22mm pipes under the bath that feed the taps and fit the pump under the bath in the space between the joists?
cheers
Mark
cheers
Mark
You'll have to fit it in hot press to take the hot supply to pump from the cylinder. If you don't have a direct take off on the cylinder a few inches down from the top you'll have to fit a surrey flange (dip pipe) . Otherwise you'll draw air back down the vent. Anyhow you'd have some racket down stairs if you put it on the plaster board between the joists!!
depends on alot, personally you want a seprate feed for just the shower, dont tee into existing, you got a suitable power supply aswell? and under bath is a NO NO. What shower you fitting?, does the 22 feed anyhting else i expect by its size it also feeds toilet and sink which means pump on that is also big NO NO.
If using original shower check it can eb pumped first!
Fitted reducer valves on all the pipework that required it (although it was a hot water pump only) and it's fine.
"You'll have to fit it in hot press to take the hot supply to pump from the cylinder"
What's a hot press ?
Are the pumps that noisey? I'm fitting a shower bath and fancied a bit more pressure than the tank in the loft can supply.
Mark
Are the pumps that noisy? I'm fitting a shower bath and fancied a bit more pressure than the tank in the loft can supply.
Mark
I would wire it from a spur on the ring main through a RCD ?
Shower I'm fitting can be pumped.
22m feeds toilet and sink before the bath, I assume that if the shower was working and a tap was turned on air could be drawn into the system ???
thanks
mark
Your toilet has a pumped supply now from under the bath? watch you dont damage ball valve
Mark
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
