universal lambda sensor
Old Nov 4, 2007 | 09:18 PM
morto's Avatar
morto
Default universal lambda sensor
hi all, has anyone used the universal lambda sensor , you just have to say weather its 2,3, 4, wire and make of car, i also read they can be fucked after just 30,000 miles
ta
andy
Old Nov 4, 2007 | 09:58 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default Re: universal lambda sensor
ta
andy
same as a normal one tbh, just you pin it out an fit a multi connecto block DO NOT SOLDIER THE SENSOR !!!
i sell loads at work,,, though if im honest we can have issues with them hence why i went for a OEM spec one for the dog
they aint much cheeper tbh, think most are around the 60 quid mark adn then universals are arouund 50ish
oh and you should take em out to clean them when you can and it helps em live longer,, though they never tell you that
Old Nov 6, 2007 | 05:42 PM
morto's Avatar
morto
thanks mate , why fit a block and not soldier?
ta
andy
Old Nov 6, 2007 | 06:04 PM
Ginge !'s Avatar
Ginge !
it can damage the sensor
the block comes with the kit though
Old Nov 6, 2007 | 06:25 PM
SteveB's Avatar
SteveB
Lambda sensors are only rated to 60,000 miles anyway (so the manufacturers say). Be careful using a universal 1 as they aren't always correct for application. Imo see if someone like NGK or Fuel Parts list a direct replacement first.
Old Nov 6, 2007 | 10:00 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
ive had far too much trouble with universal sensors will only ever use oe stuff now especially on newer stuff (obviously not wideband) never had any probs soldering tbh. as said for the price difference you may aswel get the proper one
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
