why do cossie give u joy then pain!!update 10/11/07
just had my car set up on 400's at nms 30psi peak dropping to 27psi in mid range down to 23psi at rev limiting and dont mind saying she goes very well
top set up
how ever she is now lost abit of coolant and i have got the dreaded stains down the block under the exhaust,she does not over heat no smoke etc but then again it wont as it a coopers O ring headgasket so the rings will never fail just the other part that does and looks like it has gone again for the second time!!!bloody hell
why do they do this to us
escort mk4 cossy 4x4
you can buy a alloy gasket to use with the coopers fire rings.mountune did say you should replace the fire rings when you change the fiber gasket.ferriday engineering.www.ferriday.co.uk
who makes the alloy gasket?as it always the fibre gasket part that fails!!
Originally Posted by charlie luciano
No you are not the only one and turn the boost down
Luciano
Luciano
not a option chap karl has live mapped it too that so i aint going to touch that side of it
It's the joys of cossie ownership fella..
But just remeber how you feel when they're running right..
Gave mine a blast today and MAN do i love cossies
give you such a buzz imo and i've had Evos etc, but cossies take some beating,when they're running right that is..
![Content](https://passionford.com/forum/images/smilies/content.gif)
true fella its just annoying as the headgasket should be able to cope with this level no probs
yeh indeed took her out again today took her on the motorway etc just checked the coolant level has not dropped but the stains are a tell tell sign it starting to go...again
like u say on the way home gave it littile bit of stick with massive grin factor the noise of the turbo makes when it hits 30psi
but at the moment i feel like
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
if its long studded block,and it probably is using a coopers ring gasket,you need to check the torque on the studs every 2k.
as my block is gettin done in the next week or so with long studs
Originally Posted by RWD_cossie_wil
if its a 205 block then It could well be the block is cracked...... exactly what happened to mine ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
yer its a 205 block but she aint cracked as u would be getting white smoke out the back my does not smoke at all as said she got stains down the block under the exhaust
glennshute;yer i suppose it is fella but the headgasket is £250 by itself i only had it done seven years ago/7.5 miles this is the first long journey i have had to do as she failed
Mine didn't smoke, nothing except a bit of coolant loss and using a little bit of oil, but no more than you would expect
. If it has cracked where they normally do, the bolt holes in the middle of the block, the combustion pressures stop anything entering the cylinder, all you get is slight coolant loss and sometimes the temp raises slightly, but only if you hold it flat in 5th for ages...... Hope it isn't cracked fella, but 205 blocks don't take kindly to serious power
lloyd if the mk 3 escort is yours talk bout a wolf lol bet that goes like shit off a shovel chap! ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Cake lover!
well since i first posted this i have now done around 75miles some Mway some in town and she has lost no coolant cant see any fresh stains dont know whether to get happy yet lol, ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
TPM961
15-01-2018 10:50 AM
