Gen me up on ignition coils
Ok, so here's my limited understand of how the coil works.
It charges up, then when it sees a ground pulse on the firing side, it sends a spark down the HT lead.
Now, couple of questions.
If the ground stays grounded, what happens then? Im assuming that it will prevent the coil from charging, but will it damage anything?
If the +VE side was to be disconnected, what would be the effect? Now obvioulsy the coil would stop working, but how soon would it do so, would it still pulse on the next couple of cycles till it had run out of stored charge, or would the spark stop happen instantly?
CheeRS in advance
CheeRS in advance
Arse, back to the drawing board then, as I wanted a way to cut it WITHOUT it disharging the coil, but by the sounds of it that wont be possible!
My thoughts are that it doesnt "charge up"
it just converts one input to another output constantly.
It just HAPPENS that we pulse the earthing or the signal into the coil.
IE if u put in x volts to a coil it creates x times 2 volts and half the amps - regardless. It doesn't need to "charge up"
Its not a capacitor.
RW
RW
RW
RW
explain more dude
So for arguments sake if you had a "kill" switch, that as you turned it, the spark would just end there and then, WITHOUT that one last discharge.
PS
Stupid thing is I already knew about a cut causing a fire, thats why when you hit the rev limiter on a nitrous car when you have a coilpack you potentially get a massive backfire, cause it can fire at ANY point in the cylce, where as on a distributor system its actually quite limited how far out it can try and fire as the rotor arm has to be next to one of the cylinders ht lead terminals at the time or the spark has nowhere to go at that moment so it cant happen during the intake stroke for example, which is what causes the problem.
explain more dude
explain more dude
The reason being, those sparks can happen at ANY point in the cycle, not just when you want a spark!
Testing the future
sounds like you don't need it to not discharge for very long periods at a time (gearchange or rev limit?), so why not wire it such that the supply stays on during that time?
But that still has the problem that when you remove the "block" you will get a fire, at any point in the cycle you happen to be at!
Testing the future
i get you now, it is important to you when that discharge happens - even if the engine is running properly again. but why? it will either fire a cylinder too early or not at all won't it? wouldn't cause a problem would it?
edit: it's just sinking in now
you are running NOS on the inlet plenum somewhere so don't want to ignite that mixture if it fires when an inlet valve is open
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Its not just that that is the issue though, its that when it fires you could be 20 degrees later than the inition curve was set for, and hence cause massive detonation in the engine that cycle!
..BS Motorsport..
trying with this one but cant think of a way with it been HT and not so managable. Thinking about maybe something around the HT lead coming from the coil so that when the feed to the coil is broken and thus transfering to the secondary ready for the next impulse it switches in a burden on the secondary side limiting its path. Cant think what though and not sure it would give the full kill you require.
Only other way would be to ground the HT lead prior to it reaching the spark plugs, when required, but again as nothing is readily available it would be a botch up and a) not work and b) look shit.
hard one, i'll sleep on it and probably wake up none the wiser
hard one, i'll sleep on it and probably wake up none the wiser![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Im liking the concept actually, i think you are right that it would work, but on the downside, is the fact that you would be introducing more components into the HT side of course, which is never a good thing for spark performance, and no limiter should effect spark strength when not active of course!
Nothing to do with the 3 door mate.
Its kind of linked to the BEE*R though
Ah, didnt see that. I am a blind cunt
Too many alcopops tonight
Ive realised something tonight.
Cutting the -VE or +VE has a subtley different effect to earthing the -VE
BOTH methods introduce a random spark event in the cycle, but cutting them can ONLY introduce it in a way that gives extra RETARD and grounding can only introduce it in a way that gives extra ADVANCE.
So cutting the -VE or +VE is infinitately better than grounding the -VE (which is what the limiter im talking about does I believe, although ive yet to test it)
..BS Motorsport..
How about not cutting the -ve or +ve but decreasing it slowly
"The current within the electronic ignition example shown sharply rises to 6 Amps, at which point the current is held until the earth circuit is removed. The switching speed can be seen by the angle of the vertical line at the end of the trace, any delay or slow switching will be seen as a sloping line. Any compromise in the switching speed will result in a lower induced voltage."
coil basics
with a view of creating less HT voltage that is not strong enough to jump the electrode gap
coil basics
Simon, can you tell me about the signal sent to the ground of the coil please mate.
Is it
ground for ages, then pulse to break the ground, or is it nothing then quick bit of ground following by back to nothing?
As I think I may have misunderstood how this works, I was thinkig it was mainly in a ground state, but is that actually wrong and its mainly in an open circuit state and only flashes momentarily to ground?
Is it
Modern ignition systems have dynamic coil charge (dwell) times.
This results in a uniform spark delivery at all loads.
The ignition amp on a cossies for example when told to charge the coil,
will drive the coil negative to zero volts putting the full 12 volts across it.
This results in a current of about 10 amps to flow.
This situation is called saturation.
If this condition stayed, the coil and amp would burn out in seconds.
After about 3 milliseconds, the amp backs off the drive, raising the coil
negative voltage nearer 12 volts until it measures about 5 amps
going to the coil and then holds this level.
This will NOT produce a spark even though the coil voltage across it
could have halved or more.
This is because any emf produced is absorbed by the current flowing in
the primary winding which reduces the secondary output to a point where
it is unable to spark.
A sudden release of the coil negative to an effective open circuit produces
a strong spark from any of these points in the charge cycle due to the
magnetic field being saturated given it has had time to build up.
If you reduce the drive voltage slowly to the point of open circuit then
no spark would be produced but this depends greatly on time
and coil design.
The off state is open circuit.
So the cycle is...
OFF
CHARGE FULL POWER FOR 3 milliseconds ish
REDUCE POWER to 5 amps
SUDDEN SWITCH OFF generates spark
and coil design.
So the cycle is...
OFF
remember simons just talking about modern spark systems... on an old dizzy, it was just dwelled by the points being closed, and when the points opened, a spark was produced
07-10-2015 12:56 PM
