Boost contoller...what you recommend?
looking for boost controller for cossie.
Proper digital not just bleed valve.
Whats recommended and supplied by who?
Don't really want to change chip etc in management to go dowm pectal style root unless it can be done for decent price.
how do you know the air fuel ratio is correct when turning the boost down?
just because its less doesnt mean its safe! could do more harm than good
slightly up for track days,, i wont even comment on that one
maybe it's down to the way these boost controllers seem to bring the boost in harder than a standard amal/lektron/bleed valve and will (should) hold a constant boost that doesn't vary with ambient temperature?
do they also give you the same boost in all gears? with a normal bleed valve arrangement you tend to get less boost in the first 3 gears.
I am using a Greddy Profec B2. You can adjust the gain on it to bring the boost on earlier, have warning's and safe levels, low and high boost settings etc. Good bit of kit IMO.
If only I knew how to use it properly lol
cos you set it like that before it's mapped.
but if the boost is coming in harder (because it maybe a bleed on system of control) then how do you know its been mapped for the extra (air) boost?
i would be checking it with my wb lambda gareth
personally, i am with you on this one. that is why i intend to go S8 with integrated boost control.
different strokes for different folks eh?
Not sure what other systems are like, but when we map an Omex system, its mapped at each load value. So, its doesn't matter where you set the controller (obviously up to the maximum that it has been mapped to).
These Jap controllers are very good bits of kit.
GARETH T Your car is supposed to be mapped to run the highest boost possible for your set up. When you do this and add a boost controller you can turn the boost down to a lower level for around town. Your MAP sensor sends the ECU the boost pressure and the ecu sends the right amount of fuel. As long as your not an idiot and turn the boost above what your car was set up for then you have nothing to worry about. Just like the ECU the boost controller is only as smart as the user. I hope that helps.
Do you drive your car at 23psi the whole time....... No you do not. So if it's mapped for 23 it will know what fuel to use at 20/19/18/17/16 and so on. The ecu reacts to voltage. But for explaination I'll use %. At 24psi your ecu receives 100% voltage and give the fuel for that voltage. At 12psi your ecu receives 50% voltage and gives fuel for that voltage. Do you see where I'm coming from?
I'm not jumping the gun on you but if my tuner set up my car and it was perfect at full throttle and running lean or rich at part throttle I would put my foot so far up his ass that he would need a shoe repairman to do his detal work. I spend 99.8% of my driving at part throttle.
this post in along the same lines, and stu sort of backs up what im saying
https://passionford.com/forum/viewtopic.php?t=77710
im not saying there will be a problem,, but im also not saying there wont be a problem!
That would be where the TPS would come into play. If your driving you car at WOT with the boost turned down the ECU should be able to get the mixture right if not at least rich because it senses WOT
anyway, that's the shit thing with a MAP based system. these boost controllers are designed to work with Jap cars that mostly use air mass flow sensors so they know how much air is going in regardless what the boost or throttle is doing.
i don't know why someone can't use a hot wire air mass sensor and develop a kit to install on cossies and junk the marelli shit. in fact i don't know why SECS didn't design this into his S8 ecu.
