ap 4 pots?????/2wd......update HELP
no mate
2wd saph and a 3 door are the same hubs ,so if its a genuine ap kit it should fit ,i sell these kits and they are the same kit for both cars
jp
jp
right im having greif with these now like
came in the box brand new ap 4 pots,ap 330mm discs,bells bolted on
but ggr mounting brackets(gold alloy) brand new also
weve got the m10 bolts to put the caliper and brackets together but not the m12 ones to bolt bracket to car as the bracket has a recess bit for bolts to fit in exact,hence cant use hex bolts,so im sure i can get these m12 allen bolts no problem
but the 2 things wrong is no shim kit with it and standard washers i tried are 2mm thick and i think they need to be 1-1.2mm thick to sit bang on
and for some really strange reason now that we bolted up temp with hex bolts they dont sit right,the pad over hangs the outer edge of disc by 3mm
all help greatly appreciated
thanks mate my mate fitting them says if the brackets put into a machine shop and had 3mm taken off they would fit perfect
but surely they should fit from the off,thats why i was thinking its wrong brackets
would 4x4 ones cause this problem on a 2wd set up
+discs and calipers defo correct size
Originally Posted by NUTS RuS
What have AP said / offered ?
Answer your phone tomorrow young man
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
OrionRST200bhp
29-09-2015 08:30 PM
Minirotty
11
15-09-2015 10:16 PM
