my turbo e30 project with pics shes getting there
#41
Baby Cheesus
Originally Posted by alanfordtw-15
Originally Posted by Dan@FastFord
Originally Posted by tony_turbo
a welded diff on the road is verging on suicidal surely!!!! liking your style tho
i used our drift shitter every day for a year with a welder and i have to say that it handles BETTER than an open lsd!
now wheres these pics?
love it cant beat a twin cam to drive the fuck out of on sunday and go to work on monday
#42
Team HOTHOT!
scoooby slayer
Not the first time I've cut an E30 up and made it faster
However, I would be a bit woried about the angle of your turbo - you will have issues with oil seeping past the front nose seals and the rear most bearing (exhaist side) not getting enough oil with it being sat as it is
#43
Originally Posted by Graceland
scoooby slayer
had to go there for downpipe and getting under bonnet i did read somewhere you can run up to 45 degree angle and im less than 45 so we will see. tbh im not to bothered turbo owes me nothing anyway its only an old one. and if i put oil in the inlet with a little oil can i can fill it up so it overflows straight away and thats a tiny little finger pump oil can so with actual pressure its gonna get forced into every nook and cranny of the internals im sure
#44
You don't mess about do you Karl !
Coming together nicely now.
Welded diff might be ok in a rwd car on the road but its not all that funny in a fwd car
I should have a half sensible mode of transport soon so you'll have to let me know when your out and about
#48
#49
i would seriously change your intercooler/radiator setup - maybe a 4x4 cossie i/c would be better down the side of the rad?
#50
im gonna make mounting bracket for header tank tonight and im gonna drill out a 7/8 bolt to 16mm hole through the middle and use this as the fitting for sump for oil return. im gonna try be cheeky and drill a hole and tap thread with sump in situ.
#51
Plus its free where as a plate diff is £500 minimum !
#52
Testing the future
what is the temperature of the compressed air from the turbo at only 6-7 psi? if it's less than 100 deg. C, you may as well not bother with an intercooler at all as one that will be heated to nearly that by the air coming off the rad
#53
#54
you gotta have a go aint ya mate
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
