ofab or ofac map sensor
what boost pressure can the standard ofab map sensor take,im changing my erst to ofab from ofac as the standard ofac map sensor can only read up to a bar of boost,so does the standard ofab 1 read more or the same or should i get a 3bar map sensor
OFAB std map sensor is 2bar so will read 1 bar.
You can buy 2.5 bar sensors that can reed 1.5 bar.
3 Bar is only needed if going over 21 psi.
Ollie
PS. PM me if your after a 2.5 Bar as i have just taken one of my car.
Ollie
Originally Posted by Stu @ M Developments
OFAC is 2.5bar. OFAb is 2bar. Great move. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Ollie
Ollie
so if ive got the ofac map sensor and management i should be able to run 1.5bar then so about 20psi or not,obviously i will get it setup prperly for it or should i go for ofab and get a map sensor to suit
