Decking the block?
Old Oct 22, 2007 | 04:25 PM
daviddunlop83's Avatar
daviddunlop83
Default Decking the block?
I had to get 5 thou taken off the block as it had quite a deep scratch, is this a big problem for vavlue clearance?
The head has also had the smallest amount faced off it to clean it up.
Thanks
Old Oct 22, 2007 | 04:46 PM
daviddunlop83
anyone help?
Old Oct 22, 2007 | 04:50 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Off the top of my head - 4 thou is about 0.1mm - so 5 thou isn't a huge amount...
All depends what you're running? Lairy cams? High/Low comp pistons? Valve cutouts?
Old Oct 22, 2007 | 04:51 PM
daviddunlop83
Its standard engine with standard everything so should it be ok? Im just worried incase i have ot get the pistons machined which would be better knowing now rather than when its all bolted together
Old Oct 22, 2007 | 05:12 PM
Moonie's Avatar
Moonie
The only way to know for sure would be to dummy build the engine (use the old headgasket) with some plasticine on top of the pistons. Turn the engine over a few times with a spanner on the crank then remove the head. The valve's will have made an indentation in the plastacine and will show you how much piston to valve clearance you have.
Old Oct 22, 2007 | 05:14 PM
daviddunlop83
Problem is i dont hav ethe old head gasket anymore or the olf head bolts
Old Oct 22, 2007 | 05:17 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
5 thou removed should be fine but if you want to be sure get the same removed from the piston tops, my bet is that it will be fine without though.
daviddunlop83
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
