any pc bods outhere need help resolving a problem
Old Oct 20, 2007 | 06:01 PM
cossiecrew's Avatar
cossiecrew
Default any pc bods outhere need help resolving a problem
right here goes been out and purchased a new laptop and installed the latest gAyOL software the issue im having is i can log on to the net using aol from fresh install but if i log off and sign on again aol wont work so i have to unistall and reinstall everytime i want to use aol i know its connected as im now using explorer ive rang aol allday and they keep making me unistall and reinstall this fixes it but only until i log off anyone got any ideas
Old Oct 20, 2007 | 06:04 PM
DanRSturbo's Avatar
DanRSturbo
1) Don't use AOL
2) One assume this is Aol on Vista ?? Seeing as it's a new laptop ?
3) What's the issue when you try and sign on after logging off ?? Connection error ??
4) Does this happen as well as shutting down the laptop and restarting it ?
5) What modem do you have ? BT Voyager jobbie ??
Old Oct 20, 2007 | 06:09 PM
cossiecrew's Avatar
cossiecrew
Originally Posted by DanRSturbo
1) Don't use AOL
1) not helping lol
2)yes
3)aol not responding
4)yes
5) no the voyager is not compatible with vista im using the netgear wireless router
Old Oct 20, 2007 | 06:17 PM
DanRSturbo's Avatar
DanRSturbo
Righto, So upon opening the aol software it stops responding ? Or when you hit the sign on button ?
Old Oct 20, 2007 | 06:24 PM
skeg's Avatar
skeg
Well you're using Windows which is bad enough but we all do it at some point or at least triple boot but to install AOL is just a nightmare and the reason i'm not going to help you but mock you instead.
I'll leave this one to the piss ant wannabes like Gti, Thrush etc. Thrush will probably write a 4000 word essay which won't actually help you at all. AOL By the end you'll be trying to connect a scart lead to the flux capacitor via the hifi system and wondering why it don't work.
Old Oct 20, 2007 | 06:36 PM
DanRSturbo's Avatar
DanRSturbo
Dunno if this helps ?
http://help.aol.co.uk/aol-90-vr-vist...15104309990001
Are you connecting via wirelessly or via ethernet straight into the router ? What happens if you log off, unplug the mains from the router and plug it in, then try and sign on ?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
