red sticker/green sticker L8 ECU
Originally Posted by Stu @ M Developments
Both ECU's are 100% identical.
Is it just fords way of confusing folk a little?
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
I heard that you cannot plug lambda into L8 ECU with red sticker?
Im kinda screwed right now, cos im trying to get my 1992 4x4 Cossie thru vehicle inspection (in Finland) as it is imported from Sweden. Seems like my Cosworth had green rocker cover, catalysator and lambda as original. Now it doesn't have any of those. It works well and hows that possible if the lambda is removed since I can't find it? And Finnish laws say that I need catalysator and lambda fitted, in order to make it legal. I have ECU with red sticker. So I cannot fit lambda in my ECU now? Must get L8 ECU with green sticker in order to fit lambda?
Finnish laws suck.
Finnish laws suck.
Finnish laws suck.
Finnish laws suck.
Martin
I took some pictures of my ECU and stuff. Which one should be the lambda connector?
![](http://i5.aijaa.com/b/00621/8932243.jpg)
![](http://i8.aijaa.com/b/00481/8932244.jpg)
![](http://i4.aijaa.com/b/00284/8932245.jpg)
![](http://i4.aijaa.com/b/00746/8932246.jpg)
![](http://i8.aijaa.com/b/00222/8932247.jpg)
![](http://i4.aijaa.com/b/00209/8932236.jpg)
I should have some kind of tuning chip but I haven't checked that which make it is.
OK thanks for answer. Seems like I have one of the early 4x4 Cosworths made without lambda nor green rocker cover since theres no lambda present. This was first registered to use in 1.1.1992, which is the date that matters when it comes to MOT regulations in here. Or some previous owner could've changed red sticker ECU as he removed cat and lambda.. Who knows.
Martin
But as far as I know YBJ engined 4x4 Cosworths are bloody rare. They were only made in 1989 and perhaps early 1990? I should somehow find out the date when my Cosworth rolled out of the factory, then I would know if it was originally with red rocker cover. It now has black rocker cover.
Edit: I went to check out the VIN etc. plate in the engine compartment. It said the engine type was ''N5''. And, I looked closely at the rocker cover, at some places I could see red paint below the black paint coat.. Seems like YBJ.
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
Cheers, I checked it (after some cleaning of 20 yrs old oil, grease and crap
) and it said following ''YBJ 1003''. So it is originally red top engine, but I wonder what the four numbers will tell me..
![](https://passionford.com/forum/images/smilies/angry.gif)
Just for curiousity, what are the three wires separate wires, and what does the lambda connector look like?
Thanks for your help.
sorry to but in on this one i have a 92 k plate 4x4 cosworth which has no cat is this likely to be an issue it has passed an mot in april before i got it its running lean at the mo so im not sure what to do.
07-10-2015 12:56 PM
