GT30R engine running....little problem...SOLVED!
Hi,
Today i finished my engine, so that i could turn the key to start!
@ Martin, Nice piece of work at the manifolfd part, for the external wastegate. Fits like a glove
Thanks!!
Will put some pics up later.
But i do have an idle problem. It will not idle at all
It idles at 500 rpm with up and downs, and after a while it dies.
I've checked the idle valve, and tried another one....same
I also turned the idle screw as far as i could, but the idle rpm is not responding at all. If i unplug the idle valve connector it dies immidiately.
Also did a resistance check at the ( multiplug disconnected) TPS.
Terminals 1&2 Throttle closed 100 Ohm
Terminals 1&2 Throttle fully open 480 Ohm
Terminals 2&3 Throttle closed 420 Ohm
Terminals 2&3 Throttle fully open 86 Ohm
At the moment i have no idea where to look at.
Anybody has an idea????
Regards,
Bas
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Regards,
Bas
I assume you have bolted on a manifold and a large turbo but have not yet had a remap ????
If so...
You have upset the air flow of the engine which is not able to be
measured by the ecu so it is not set up correctly.
Also,dont drive it hard on boost as you will melt it as your engine will
consume more air without adding extra fuel.
If so...
If so...
If so...
I can not imagine that this is disturbing the idle that much. Also the idle screw does not respond at all.
I know that it's consuming more air but not that much on idle. And off course i will not boost it, that will definitely destroy the engine.
There will be a aftermarket stand alone system in the car soon, but first i want to settle the idle problem.
If i rev at about 1000 rpm, the engine is running great, but if i let go the throttle, it dies.
escort mk4 cossy 4x4
a mate had a similar problem at the weekend,checked the ohms reading at the ecu for the temp control,got nothing,connected a new one to the loom and it ticked over ok,could be the same problem
sure you aint got an air leak on the inlet?
Map sensor pipe conncted? all the others blocked off or used?
that will make it do what you describe??
its probably something more simple than you think mate.
good luck,
good luck,
Map sensor is connected, and all the other ones are used ( fuel pressure regulator, blow off valve , boost controller)
Regards,
Bas
*From T35 .63 TO GT30R.
*From 2wd inlet manifold TO 4wd inlet manifold
*Pistons
*Inlet Cam
*Ported head
*Double valve springs
I'm using the same throttle body as before.....just a std 2wd one.
Already had changed ALL the sensors a year ago, and was running great on greys at 28 PSI.
Regards,
Bas
*Pistons
*Inlet Cam
*Ported head
Regards,
Bas
1st to 200 without NOS
Originally Posted by Cosworth Bassie
You mean the idle screw?
![](https://img511.imageshack.us/img511/408/visderalentise0.jpg)
If so, i allready I turned the idle screw as far as i could in and out, but the idle doesn't react at all![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Solved
Because of the new set-up i think the idle valve was just a little bit out of his range.
But after screwing the throttle stop open a little more it didn't die anymore, and the idle valve is back in his range.
Thanks Martin!! Such a simple solution after all.
But the engine still wasn't running smooth at idle. But after some timing changes of the cams, it idle very nice now!
Regards,
Bas
Regards,
Bas
After all, it was a simple fix yes
Pictures are crap, made by a phone, but want to let you see, how the external wastegate fits. Perfect fit from Martin.
![](https://i42.photobucket.com/albums/e309/bas309turbo/Cosworth%20motor%20ombouw/Photo-0133.jpg)
![](https://i42.photobucket.com/albums/e309/bas309turbo/Cosworth%20motor%20ombouw/Photo-0134.jpg)
Regards,
Bas
Regards,
Bas
glad it was an easy fix
sorry to ask but as our sapphs have the battery on the other side will that not get a bit hot next to the wastegate? ust remember it saying on batterys not to get to hot or can explode
wait til you time the cams for power and the idle with be crap again ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
sorry to ask but as our sapphs have the battery on the other side will that not get a bit hot next to the wastegate? ust remember it saying on batterys not to get to hot or can explode![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
There is more space then you think between the battery and the rest
@ Coskev,
I'm also looking forward to it. But first the MOT, then putting in the aftermarket system. Driving in the engine properly and mapping it.
Regards,
Bas
