horn *urgent*
horn *urgent*
my horns stopped working on the saff, checked the wires behind it, they are fine, is it fused? any other reasons people can thnk of?
have the mot at 2.30 so need it done for then
cheers
R
cheers
R
horn
have you a aftermarket steering wheel fitted i had the same problem and it turned out it was the connection between the steering and the nuw hub
hope this helps
you can try bridging the two wire on the steering side of the connected to see if the horn is working
hope this helps
Re: horn
hope this helps
hope this helps
it has a RS 3 spoke on it with the ford boss.....
You should check the horn actually works as a lot seize up through lack of use, some can be tuned back in with screw but not always.
If not the NAUTILUS horns are recommended, I have one of these each side and each is a two air horns in one thing, if you bend the bracket through 90 degrees(on straight part) they even fit in the original place on these brackets, then just make up a short earth wire for each to the bracket.
Jesus they are LOUD!!
Originally Posted by charlie luciano
There's also a relay for the horn too,
Hang on haven't you sold the car?
Luciano
Luciano
right, when you bridge the horn terminals behind the steering wheel, it makes the horn relay click, but no noise??
does this mean the relays shagged or the horn unit itself
wheres the horn located on a saff, i cant see it
Originally Posted by dojj
pull the cowling off the steering column
find the little long plug for the horn
pull it apart (from the foam as well)
short the wires out on the plug
if the horn works then it'll be the rings on the wheel or the spring loaded contact that have carboned up
horns
lye under the car at the front the horns are located at the junctions of the chassis legs and the cross member on the underside of it
Note they are both earthed and need good contact
failing that try direct wiring them to by pass the relay this will make sure they are working
if the relay clicks then it should be working ok get a multi meter or 12volt bulb on the relay outputs to check and make sure it is sending the voltage out to the horn then trace the wire all the way to the horn check at the connection to the horn u should have power if you have now check you have a good earth if you have all of this and it still doesnt work then the horn is fucked as said more than likley a wirering fault for both of them not to work
Jack and the Beanstalk
15-08-2015 04:27 PM
