oil pressure
21-10-2007, 02:24 PM
Quote:
Originally Posted by cossiedave
all done lads it was the pump,hits 78psi now on cold start up .
Glad its fixed mate.
Just out of curiosity, how long did it take you to change the pump?
21-10-2007, 05:21 PM
Quote:
Originally Posted by Ginge !
im sorry,,,, THERES NO WAY THAT SCOTLAND HAS EVER BEEN 14 DEGREES
the weather has not been too bad this year mate...still no grit on the roads and it half way thru October
21-10-2007, 06:33 PM
about 5 hours m8
21-10-2007, 06:35 PM
Only 5 hours dave, you must be getting old
21-10-2007, 06:37 PM
21-10-2007, 07:54 PM
which way did you do it remove the engine or drop the subframe down.....
21-10-2007, 08:43 PM
21-10-2007, 08:51 PM
had my cos out tonight and remembered to take note of oil pressure on start up at idle. its 5.8 bar 84.1 psi
23-10-2007, 09:57 PM
What presure you getting on hot idle mate?
23-10-2007, 10:00 PM
press on hot idle is totally dependant on idle speed...
I had my idle sped upped to 1100-1000 rpm and now se 1,8 bar at about 80 deg
24-10-2007, 05:24 PM
too true with my lumpy tickover mine goes up and down
SMILER258
28-09-2015 09:04 AM
