oil in boost pipe and oil coming out of dump valve
Old 13-10-2007, 06:39 PM
jawanne
jawanne's Avatar
Default oil in boost pipe and oil coming out of dump valve
as above any idear wat is causeing this thanks
any info would be great
Old 13-10-2007, 06:41 PM
col cos1
col cos1's Avatar
normal,especially on high milage cars
Old 13-10-2007, 07:00 PM
Lee_R21Turbo
Lee_R21Turbo's Avatar
Knackered turbo also could cause it!!!
Old 13-10-2007, 07:03 PM
jawanne
jawanne's Avatar
this engine has only done less then a 3 grand of miles could it be the turbo or the oil breathering sistem..as when i took the cross over boost pipe off they was oil in it .and theres oil over the dizzy cap as its coming out of the dump valve when it dumps..........
Old 13-10-2007, 07:06 PM
rapidcossie
rapidcossie's Avatar
is the breather still plumbed inot the airbox?
Old 13-10-2007, 07:23 PM
TurboInsania
TurboInsania's Avatar
ye ur right euan the breather aint up to the job
Old 13-10-2007, 08:33 PM
jawanne
jawanne's Avatar
hi are you on about the breather next to the cam cover....
Old 13-10-2007, 08:34 PM
jawanne
jawanne's Avatar
rapidcossie
yes it stillis are you on about the metering head box
Old 14-10-2007, 11:41 AM
col cos1
col cos1's Avatar
if you get oil at the filter its the standard breather that cant cope with increased pressure,as soon as i stage 3d a saph of mine it did this
but ive seen plenty cars that blow a slight bit of oil out the dump valve
Old 14-10-2007, 01:01 PM
xr4x4rs
xr4x4rs's Avatar
last time i had oil coming out the dumpvalve i had a cracked piston on my rst
if you breather system is std and goes though the metering unit, then modify the system so it goes to atmosphere
this will stop the oil recirculating as it wont be going onto the metering unit for the turo to suck it up and chuck it through the boost pipes
alls you do is block off the breather port on the metering unit and the vacumn feed on the inlet manifold
this is what i dont but i did have a bailey tank aswell
so not 100% sure it will work on a std set up
blackbeautyzetec
29-08-2015 02:11 PM
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
Churtz
15
13-08-2015 06:40 PM
rsstav
11-08-2015 04:22 AM
Dazts1
Was It You?
02-08-2015 06:44 PM
Quick Reply: oil in boost pipe and oil coming out of dump valve
