Torque- How to make it?
Old 13-10-2007, 03:02 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Default Torque- How to make it?
What are the major factors in making a majorly grunty YB? Most 500BHP engines you see are around 450Lbs/ft, and the further up the power you go the more torque you seem to loose.
Is it possible to make 500Bhp and 500Lbs/ft on a T4 YB? Is it just a case of running a huge boost spike with sensible cams? Most of the other internals will be std items except low comp pistons
Old 13-10-2007, 04:02 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
on the whole...
boost= torque
smallest ports you can get away with= torque
mildest cams you can get away with= torque
Old 13-10-2007, 04:05 PM
RWD_cossie_wil
so a T4 on std cams and a lightly ported head should get close to 500Lbs/ft? It's running 2.5Bar spike+ held boost , not had chance to get it RR'd yet.
Old 13-10-2007, 04:07 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
What car will, Saph?
Old 13-10-2007, 04:09 PM
RWD_cossie_wil
yes mate, the silver saph
Old 13-10-2007, 04:11 PM
Charlie Chalk
Unknown.
When you looking at actually having this on the road?
Old 13-10-2007, 04:12 PM
RWD_cossie_wil
got the head back yesterday, so should be back together monday and get it MOT'd and insured asap ...then wait for the 7" 4x4 diff to shit it's self since its not 2wd
Old 13-10-2007, 09:28 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Default Re: Torque- How to make it?
Is that a fact .
Old 14-10-2007, 07:21 AM
Mark Shead
Mark Shead's Avatar
Not a chance, With that spec you would be lucky for see 400 to 420ftlb,
The sum of a engine is just more than a small port head and low comp pistons, To get 500ftlb the engine will need to be a little more trick than that.
Mark
Old 14-10-2007, 10:32 AM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
isnt the power and torque more about the volumetric efficiency of the engine?
Old 14-10-2007, 11:11 AM
RWD_cossie_wil
Mark
What sort of areas should I be looking at improving then?
Old 14-10-2007, 11:13 AM
RWD_cossie_wil
Is that a fact .
Rod, it's all very well on your spec engine, but I'm talking about a std geometry YB , yours is so far removed from a std engine its not really the same thing is it?
Old 14-10-2007, 11:18 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Is that a fact .
Did you not see the mental torque and powerband his "normal" old T4 and 8inj engine made? Thats was summat like 504bhp and 540lbft if i remember right.
Old 14-10-2007, 11:38 AM
RWD_cossie_wil
Thats what I was interested in Stav
Old 14-10-2007, 11:56 AM
Gatecrasher
Not welcome...
Gatecrasher's Avatar
Just tagging this as im quite intrested in the question and hopefully comming answers
Good topic
Old 14-10-2007, 12:01 PM
Fiecos Dan
Fiecos Dan's Avatar
My memory comes up with
@ 37psi boost, 492 lb/ft @ 4500 rpm, 504bhp @ 7000rpm
T4 and 8inj, but cant remember if it was a std stroke,bore or rod length.
Old 14-10-2007, 04:12 PM
Mark Shead
Mark Shead's Avatar
Mark
First look at cams stock are nice but they wont cut the mustard, Then IMO management but others will disagree.
Mark
Old 14-10-2007, 04:26 PM
GARETH T
GARETH T's Avatar
Mark
Mark
i disagree totally, HOW will the management help make more power?
Old 14-10-2007, 04:31 PM
Daviet
Daviet's Avatar
did staffy not lose torque when he changed his managment
what type of torque did the old touring car spec engines make as they were apparently over 500bhp
Old 14-10-2007, 04:33 PM
Daviet
Daviet's Avatar
dont think kev sharp ever got a figure for his escort did he? as that must have had some power and was that not classed as touring car spec.
what torque does euans car make?
Old 14-10-2007, 04:34 PM
scoooby slayer
scoooby slayer's Avatar
have to agree i think its a total waste of money up to 500 hp anyway
Charlie Chalk
Unknown.
Mark
Mark
Explain then please
Old 14-10-2007, 04:35 PM
rapidcossie
rapidcossie's Avatar
mines must make not bad torque as it was wheelspinning in the dry at 8k in 3rd today on way back from supercar day at KH
Old 14-10-2007, 04:40 PM
rapidcossie
second thoughts maybe its cos i still run the standard rear axle
Old 14-10-2007, 04:55 PM
Gatecrasher
Not welcome...
Mark
Mark
Explain then please
Have to Admit im more intrested in what cams are Mark's preferd choice to get a Genuine 500/500 engine
In regards to ECU's making more power i know fuck all about it to be honest but at a stab in the dark would it be because you can map a car better on newer engine managment than you can on old style managment, so you get the best from the engine thus more power?
Good topic this
Old 14-10-2007, 04:56 PM
Mark Shead
Mark Shead's Avatar
Mark
Mark
Accuracy and speed of management and for it to make changes, This allows you to map closer to the edge over a wider band of engine operation.
Mark
Old 14-10-2007, 04:58 PM
Mark Shead
Mark Shead's Avatar
No he did not the prev graph was not correctly calibrated to his car.
Mark
Old 14-10-2007, 05:00 PM
Gatecrasher
Not welcome...
So was i sort of right in what i said Mark?
Old 14-10-2007, 05:04 PM
XRT_si
XRT_si's Avatar
Interesting topic
Old 14-10-2007, 05:05 PM
Mark Shead
Mark Shead's Avatar
IMO yes
Mark
Old 14-10-2007, 05:07 PM
Mark Shead
Mark Shead's Avatar
Mark
Mark
Explain then please
Good topic this
The cam choice if affected by Head ports/comp ratio/turbo/exhaust manifold among other things.
Mark
Old 14-10-2007, 05:09 PM
glancy2081
glancy2081's Avatar
does running a comp ratio of 8.0-1 as apposed to say 7.2-1 make more torque
Old 14-10-2007, 05:12 PM
Daviet
Daviet's Avatar
Mark
Old 14-10-2007, 06:51 PM
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
...firstly you wont be able to physically run 2.5 bar boost thru a lightly ported head...the max will be 1.5bar or its surge city..i know i tried it!
Old 14-10-2007, 06:56 PM
Gatecrasher
Not welcome...
Mark
Mark
Explain then please
Good topic this
Mark
Doesnt your 500/500 engine run GT30 / 2wd manifold? dont know about CR or Cam Choice but i assume the heads pretty worked on
Old 14-10-2007, 07:17 PM
GARETH T
GARETH T's Avatar
Mark
Mark
Mark
how close are you mapping to the edge then? do you think the L8/p8 isnt good enough, i cant remember the stats of an L8 but they aint that poor
Old 14-10-2007, 08:23 PM
scoooby slayer
my head is nms middle of the road port size ie inbetween standard and touring car spec.
to stop surge im checking my msd mapping sheet now boost is capped at 22 psi > 4700 rpm, 25 psi > 5400 rpm and 32 psi >7800 rpm
i am certain ive lost some torque by doing this but i see it as a good thing as my gearbox and diff will last longer.
once u get up the revs abit the engine will consume it but 32 psi at 4000 rpm well boost gauge was fluctuating by 6 psi herific surge, a set or air injectors and a decent mapper will cure it
Old 14-10-2007, 08:27 PM
Mark Shead
Mark Shead's Avatar
Phil
I have just done a completly stock RS500 2bar boost at 4k no surge, Realy awsome bit of kit .
Mark
Old 14-10-2007, 08:28 PM
rapidcossie
scoooby slayer
Any plans for sorting the engine out so you can run to its full potential?
Quick Reply: Torque- How to make it?
