WTF Is wrong with my Pulsar! (It is the HG :cry: pg5)
#46
If for some reason say it is the turbo, and thats buring oil.. would it make the block hotter and make the water temps go as high as they have been?
does it get hot even with no boost....
#48
Weird thing is if there's no comp loss or signs of headgasket gone then it really sounds like a water circulation problem to me.
But then..
What is also worth thinking about is that this happened a while back before you changed the pump, yes?
hmm, weird it gets that hot soo fast though if it was a cracked head or block?? I've had a cracked head before and it wasn't like that and gave headgasket type faliure syptoms. I'd be pretty suprise dif the block was cracked and you still got those decent compression readings..
It's almost like something happened a while back like some freak water blockage somewhere. What was the scenario when it 1st got hot, ie before you changed the water pump? thrashing it or anything?
But then..
#49
bummer
ive had a blocked radiator once
in a rst, did the same sort of thingish,
hot hot hot and drove shat
any chance you could try another rad
without buying one.
chin up
chip
without buying one.
chin up
chip
#51
But then..
But then..
buy what about the blue smoke out of the back.
is it a bit or lots of smoke Rad.
a bit may be ok,a little bit of wear in the engine/turbo etc...but if there is loads coming out then thats something else.
#56
When you refilled the water system did you do it cold? It needs to be done cold and on an incline (aparantly).. park on incline, in car heater to max temp, remove bleed screw on thermostat housing, fill radiator until a steady stream of water flows out of thermo housing. Chuck bits back on and fast idle it at 2,5k for a while.
From reading on gtroc it seems very important to do the bleed cold and on incline making sure a nice flow comes out the bleed hole. Read a couple of posts and one guy picked up some air from split hose repaired and refilled and was getting temps off the gauge like you, the bleed above sorted it.
It may also be the case that you have picked up some air for an air lock in the first place for it to all start. There are some water pipes round the back of the block below the plenum that are a cunt to get to that can split.
#60
this one says bout split hose, repair, then refil and temp off gauge, 2nd page explains bleed and then the guy has success.
http://www.gtiroc.com/forums/showthr...ht=overheating
#66
Originally Posted by Lee_R21Turbo
what about the smoke though. ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
#67
Rad nothing to do with the problem Chris had last year with it? think at bedford day he had a problem something to do with oil. cant remember what is was or was done to it? but i remember there being a bit of oil everywhere in the bay due to something that needed doing?
#72
Originally Posted by RSrussell
Oi nubnuts you haven't stated if your leaking oil or not, then it may rule out a cracked block ![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Limping home at 10/15mph smoke is pissing out the exhaust and a strong smell of oil, compressions fine so it cant be rings? no leaks either of water or oil
Do people not read the whole thread before they ask questions?
Numb Nuts
![007](https://passionford.com/forum/images/smilies/bond.gif)
#74
i think just because youve got good compression doesnt mean ur oil rings are ok. the overheating could of fooked ur lower ring the oil ring hence burning oil but compression ring still ok. just a thought
#79
So far im with the Long rag and a lighter i keep telling my m8 that with his frst things always braking / going wrong
Hope you sort it and it dont cost to much
