i feel sick
i feel sick
hi av just finished puting my car back on the rd bin out in it to day and its slow..it has a big kent cam t3 and a motorsport chip low comp pistons i dont no why but me standed turbo escort was faster...i dont no if the cams are out mite be over fueling i dont no it move well but it shoyld be better then a saxo vtr i cant belive that a saxo was up my arss could a rollering rd sort this and will they set the cam and fueling i feel so sick plz can some one help me standed rst was fast no joke
Originally Posted by martin-reyland
Who did the conversion? Audi 20V conversion is the way forward
jawanne is boosting ok? do you have a guage?
taken it for a setup at all?
its running 6 psi and i have not had it set up yet..its ok in 1st gear and 2nd.but it feels like its holding back thats y i think it over fueling and i dont no if the cam is bob on
cheers do you no wat wires go to the amull valve i no its a + and a - but wat wire goes where as some one said just put a live and a earthe on it and useing a swicth so i can run two boost setting
regards mark
Originally Posted by Stu @ M Developments
What a topic!! 100% Internet tuned.. and its slow. Fancy that!!
seriously mate, I know fook all about cars, engines, sprockets and flange wassers but it sounds to me like your taking some advice of people that probably know as much as I do
a little knowledge is dangerous chap for the sake of the hard work you have done to date with the donkey work take it to a pro and get it sorted
help him out
Guest
Posts: n/a
we all do it at some point i remeber building my first cvh after getting pissed off with paying the earth i looked at it labled the wires sensors ect so id know were they went back to took it apart outside my house on the street rebuilt it new bottom end head gasket ect fired after 2 mins and continued to run for along time until i found a bleed valve it went like fook for about a week befor makeing like a talibans nissan in a market place in bagdad its fun but costly save up and see stu
some lad off here said i need to plug my amul valve up thats y its low boost wat boost does standed escorts run......thanks
As said fella, get it set up properly, you may cause lots of damge if not.
Plus they will make the most of you work and you'll be smiling all the way home with saxo's blown into the weeds.
Where are you based, peeps may be able to recommend a good tuning place local to you.
I had a two stage boost, 7psi, and 17psi, oh baby, when I flicked the switch, life moved very quickly in deed i miss the sensation of a turbo
rsguy
44
29-09-2015 03:29 PM
