WRC Long stud trouble-Need help ASAP!!-sorted-thanks MSD!!
Well, I have had my block centre 6 long studded, the problem I have now is that the head is too small to fit a decent size socket onto the 18mm nuts
. I have contacted the company who did them, and they recon a normal socket should fit fine. I am just wondering if its becasuse its a small turbo escort cossie head the bolt holes in the head are slightly smaller?
I have had a few sockets machined down, but I have split the "good" one on the final torque stages.
.... I have been advised to torque the studs as normal, ir stg 1 20-25nm, stg 2 45-50 nm, then stg 3 170-180 degrees final turn. Does this sound right, as the socket split at about 120 degrees. What can anyone reccomend doing the long studs to?
Apparently the only other option is to take the head back off, strip it down and machine out the head bolt holes to give a bit more clearence, I am very unhappy about doing this, as I don't want to take any strength away from the areas around the lifters
Has anyone else ever run into problems like this?
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
The problem of some studs is that the nuts are too big especially if you have a 2wd head. When I bought the studs for my mate to fit a 2wd head the dealer gave me 2 options, one of them being a different size of nuts (16mm) so the socket can fit easilly like when you fit ARP's. When we fitted them to 4wd heads we had that type of problem so we machined a socket to enter the head. ( At first we took the extra material of the socket by grinding and it cracked immidiately then we machined another one down with a torn and it hold for several engines) .
Originally Posted by IANS2RST
u need an 18mm socket that has been machined down ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Also a BIG thanks to Stu@MSD
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Thanks for the replys anyway guys
Originally Posted by Butch.
so are the torque settings for longs studs the same as standard head bolts then?
glad you got it sorted mate
