anyone know anything bout vauxhalls.....
Hey guys. Dont know if you can help. Got a vectra sri at the moment and the rev counter is dead and the speedo is flicking very fast like a relay has gone or something. Does anybody know where these feeds come from so i can check them out. Also any particular relays or fuses they run on. Thanks guys.
*** Sierra RS Custard ***
If its effecting both, then it sounds less likely its the two feeds both at fault, and more likely its an earth problem perhaps?
sorry, cant help beyond that as I dont know a lot about a vectra car loom, try the VVOC site thoguh, someone might have had similar on there and can help you.
Originally Posted by Gaz 88
only thing i know is there shit
you can follow the feed for the rev counter from the ecu then through a plug on the bulkhead then up to the back of the clock. i can't remember what pin number on the ecu but can find out if needed. it's a green wire.
the speedo gets it feed from the abs sensors
vectras have some common fault's but that's not really one of them. i'm on number 6 and never expirienced any speedo fault's.
depending on what model,engine, year you have i've got spare clocks if needed
Rod-Tarry
237
18-03-2016 09:13 PM
