fuel pump voltage now with new readings 7/10 !
Old 07-10-2007, 05:51 PM
  #41
mechanic28
mechanic28's Avatar
Originally Posted by scoooby slayer
ive got 14.3 at the battery and 13.3 at the pump and it was checked and mapped like that by stu at msd and he was happy so must be ok.
cool thats made me feel abit better see your running 32psi as well i am only going up to light blues at a max boost of 26psi
Old 07-10-2007, 05:56 PM
  #42
mechanic28
mechanic28's Avatar
Originally Posted by SteveB
I'm sure others are wondering this as well....
I'm going to rewire mine over winter...... now how do ya do it with an idiots guide...lol (I'm ok with the earthing bit)
Is it a case of from the battery to the std relay then onto the pump or more complicated than that??
Steve
easy fella bit more work required if u want to follow the original wiring around the fuel tank like i have etc need a fused live straight from battery to a relay (40 amp one ok)then use the feed from your cut off switch to your pump(if u want the cut off switch to be in the circuit still)for the switching circuit of the relay,use your original pump earth to earth out the switching circuit,then a fresh live down from your new relay to pump and new earth from pump to body
or look in technical archives pics there etc
click here this is how i done mine
https://passionford.com/forum/viewtopic.php?t=158783
Old 07-10-2007, 05:58 PM
  #43
scoooby slayer
scoooby slayer's Avatar
should be fine mate, ive topped 160 a few times and hit the limiter in 4th at about 140 a few times and exhaust temps havnt gone above 700 c. at the end of the day its a 12 v pump and youve got 13 so cant see any problem personally
Old 07-10-2007, 06:21 PM
  #44
mechanic28
mechanic28's Avatar
hope not still going to try and get some more volts there would like to see 13.5 really
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
15
07-10-2015 03:43 PM
Adam Graham
06-09-2015 06:04 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: fuel pump voltage now with new readings 7/10 !
