GT30 turbo power
#122
Originally Posted by miller3
Originally Posted by Dan
that looks like the gt28 i was looking at in the blokes car the other week.and it had the a/r.70 on the housing.am i being a thick cunt and missing something?
#127
1st to 200 without NOS
#129
Following on from this, I got my GT30 on Saturday off Martin H!
But what connections do I need for it, I've got the water banjo's from my old T34, but cant remember what else is needed! whats the oil return like on a cossie?!?!?!
Any of the related items on the bottom of this page help?
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
#130
DEYTUKURJERBS
Maby it was a GT28 with a 30 compressor housing
argh! now that means what?i take it the front part with the a/r.70 on it is a gt30 then.
#132
DEYTUKURJERBS
Originally Posted by Porkie
I drove the Sierra quickly the other day. Sweet mother of GOD that GT30 is the BOLLOX
I LOVE my engine.
Stavros you NEEED to drive it.
I LOVE my engine.
#134
Originally Posted by Chip-3Door
Id like another go now sometime too please Lee
Always a bonus in a 600bhp car
Top mod that
#138
If my T38 turns out to be dissapointing, I think it will have to be a GT30 ... What trim are you going for yeti? And what cams will you be running? will they all do 500ish BHP on the right core engine?
#141
*** Sierra RS Custard ***
Originally Posted by RWD_cossie_wil
just want to keep it as low lag as possible. - seeing close to 500Lbs ft of torquewould be nice as well, 500BHP would just be a bonus.
#145
Not welcome...
#146
Gatecrasher
I bought that over a month ago Ben, only picked it up Sat.
Chip-3Door
It might be cheaper Chip but its at a cost! Not sure why or how but the internal produces less than an external gated affair!
I'm sure Martin will enlighten us!
Chip-3Door
#148
Gatecrasher
Chip-3Door
Chip-3Door
If its out and out power you are after, the external one is a better option yes mate.
Internal one is just popular as its a more simple direct replacement for a T38 etc.
#153
Spec example:
Standard comp healthy rebuilt engine with mild head porting and standard cams. 2WD exhaust with 4x4 inlet, grey injectors and the 3 bar 044 etc. Now with a t34 am i right in saying 400 is the limit? maybe with a cam swap?
What benefits would a gt30 have over t34 with this spec? and what kind of power could be expected?
#154
don't think the 4x4 manifold will flow enough for 500ish will it?
But when talking inlets............... Oh there's a can of worms!
Ps I'm running the small turbo inlet
#155
Originally Posted by radiant red
Spec example:
#156
Sweedish plenums are a waste of time unless you are after ultimate horsepower, they ruin low down throttle response. Even a std 4x4 plenum with a 14mm spacer will run well over 600BHP, so why change somthing thats not broken?
On the 4x4 exhaust manifold I am sure I have heard 450BHP is the flow limit?
#157
well im running 4x4 plenum with no spacer and made 472.3 at 30 psi. and i hold over 32 on the road so its over 480 in fourth and fifth gear. im on the limit of my inlet and head now though.
#158
Spec example:
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
