My Powerstation RR Result - Misfire city :(
recently have been having a few problems with regards to a misfire, so last night cleaned the spark plugs and thought it was ok (plugs had only done about 400 miles).
Only happens at high RPM and it happened on every run
Took plugs out there to check the gap, and seemed fine, so not much I could do even though they said if it was a plug issue they would let me run it up again.
The last run, the car had to be run at about 70% throttle and even then still misfired...
Will change the plugs and leads, and if it doesnt cure it, I'll have to get Karl to have a look at it for me...
Despite all the above, here is the graph they printed out for me....
Re: My Powerstation RR Result - Misfire city :(
Originally Posted by crazycage
why so much transmission loss??
Still, I drove it back
Yes, but not taking anything away from Stu, the dyno measures power at the wheels and for that it shows 196bhp, which is by all accounts poor for the spec. I think there was a fault with the run personally.
I don't think the Rollers were very good yesterday, the power figures seems slightly low on a lot of cars, and the torque figures were all very low, even using the correct NM to Lbs/ft conversion.
My mates saff ran 415BHP, and 315 Lbs/ft, but recorded a 196BHP transmission loss - A lot of people seemed to be missing 50+ Lbs/ft of torque off thier expected figures odd.....
And Stu's car, I think about 30 people are now suffering from tinitus from the expolsions coming from the exhaust
Originally Posted by AndyRST
Looks like yesterday was "National Lose power on a Rolling Road day"
Hey Stu!
Nice to meet ya yesterday
What exactly did Curtis say to you about it then as i couldn't over hear the convo properly.
It did sound a bit like boost cut to me but i guess it all depends on what the boost limit is on your ECU. It seems a little coincidental its happening now the weather is colder aswell if you get me
Perhaps some people on here best do a bit of research and actually find out how a MAHA rolling road works first, before slagging it off.
Torque is down on a MAHA compared to say a Dyno Dynamics, where as power is slightly up compared to a Dyno Dynamics.
Ignore the PAW (on a Maha) as these rolling roads are geared towards Fly Wheel calculations.
Originally Posted by SafeChav
Hey Stu!
He said it might have a bit of overboost, or plugs might be knackered!
Bloodyhell, check the losses. Someone fitted 4wd?
Hey Stu!
Have you checked the plug gaps like Curtis suggested? Might be worth turning the boost down a touch aswell to see if that cures the problem, you won't have lost anything if not.
Fairplay though, that car had some serious grunt
The flywheel figure is the accurate reading and the one you should be looking at for this rolling road.
IMO Stu...the RR run was a farce....as soon as it misfired like it did, it was never going to improve.
For them to try it time and time again was not a good idea at all! hopefully no damage has been done to your cylinder head in particular!
trying to get an accurate figure by using part throttle and driving through the misfire was a bit strange too
whether it's a plug fault or summat else i don't know, but i'd personally speak to Karl about some Denso Iridium, have the gap on that cam trigger doofa checked and maybe try new leads.
personally i think it's plugs though.
Yeh he was there, helped me check my plug gap.
Ive got some new 071C's Martin, should be gapping them later and seeing..
I wonder if it is boost limit
I suppose Karl would have to have set one?
Has to be said, I was quite shocked they didn't put a probe up any of the cars exhausts to monitor the AFR either .... thought that would have been a very good idea to keep an eye on peoples engines.
Figures were very strange, operators said Torque was at the fly, and everyones was very low for their spec, even on cars who hadn't changed spec since last time they were RR'd. Power seemed sensible at the fly figures, but wheel figures were all over the place.
Have to agree with Stavros here and say that its hard to know what to belive - The only car I saw make what was expected or thereabouts was Si's saff, which made 397 BHP and 393 Lbs/ft, which was just about right for the spec, a lot of other cars seemed way off, even with no apparent problems.... odd
If its any consolation, i was chuffed with the figures my trackday shitter produced
Plus it sounded good bouncing into the 8000rpm rev limiter !!!
I remember one of the powerstation guys saying something about the transmission losses being all over the shop, but cant remember exactly what he did say
Originally Posted by sortedcossie.com
i'm going to get mine power run somewhere else i think.
all the graphs in PDF format can be found here
http://www.rs-mania.co.uk/forums/ind...=0#entry234214
Well yea Karl probably did set one, but as the weather gets colder and the air gets denser its more likely to hit the boost limiter
If the new plugs don't make any difference it'd be worth finding out what the boost limit is set as, i really don't think its anything major though as they nearly got a clean run at the slightly lower throttle.
I'm still interested to know what cam it has.
Changed plugs yesterday as was only firing on 3 and feels like a new car again. Yet to test high boost in 3rd though..
Stu those misfires on Saturday were comedy sounded like bin-laden was in the workshop
Originally Posted by Stavros
No flywheel figure is ever accurate on any rolling road.
Fact.
Fact.
As regards to your understanding of how a RR works you really need to research on how a MAHA is both set-up and works. The simple fact is it is not meant to give any form of meaningful PAW's, regardless of what your logic dictates. I would explain, but I would get it all wrong even if I have had it explained to me a thousand times before.
